Install of new ES Trailing Arm bushings:
Chris, or Genes1s
How do you guys deal with the torque specs on all the bolts on a job like this?
I always wondered do you just tighten down and move on or actually check each bolt to the FSM with a torque wrench etc? Seems like over kill?
Getting ready to do this myself... just need a lot of energy/motivation/patience to do it.
Chris don't think u ever mentioned this , how long did it take you?
And these metal lips that you have to grind off once the rings are out, I can't see them in any pics but I guess the metal lips would prevent the bushing from sliding in correct?
Thanks all!!
Thanks all!!
Found the part at autozone like you said
http://www.autozone.com/autozone/par...9_253662_5934_
i had to search for the 2000 maxima as nothing showed up for my 4th gen.
Comparing the part numbers at Courtesy there is a slight difference... 32 vs 33 (forgive my newbie ignorance) are these the same or not? "55501-A33B002" vs "55501-A32B002"
http://www.courtesyparts.com/kb_sear....php?keywords=[55501A]+\(a33b&cPath=1956_1957_2046_2050
http://www.courtesyparts.com/kb_sear...1784_1873_1877
thanks! I'm excited to do this.
Chris, or Genes1s
Thanks all!!
Thanks all!!
Time on the job? Hard to say because I did other things too. Like re-installing my Stillen sway bar - which two bolts broke and I had to dig and find a suitable replacement in my bolt/nut box. Repainted the bar. Repaired the rear beam and arms and lateral link. I had the wrong dremmel tips
For the job, cheap, broke like 3-4 during process.....that added lots of time to the job. I also goofed off and did other stuff too, dealt with kids. Maybe 9 hours start to finish but NOT because this is anywhere near a 9 hour job, no sir. I think 3-4 hours is more than time for this.
Yeah, you should see the lip in the image where the ring is being rotated before removal. What I didn't photograph, are the little nipples at the center of the opening which also must be grinded away.
Chris, or Genes1s
Thanks all!!
Thanks all!!
Clean the nut with brake clearner/acetones to remove any dirt or grease. Should never grease any bolts and nuts. Those nuts are designed to stripped first before the bolt, so yes you can strip it if you yank it too hard. A good torque spec is just below the yield strength of the nut that gives you the best repeatable compression load on the joint.
Since I replaced my RTA bushings few weeks back, I replaced the sway bar end link with moog and sway bar bushings with and sub frame bushings with ES. Along with the RTA bushing, the car handles pretty good. Still have a little more body roll but defenetly much better than before. The trade off is NVH is very noticable. If you have lower profile tires, you would feel it more. I took my tires pressure down to 30 psi and it hel[ed to smooth it out a bit. I'm planning to install the LCA ES and moog ball joints, moog tire rods, and steering rack bushings when I install the LTB.
Read post 108 in this 4th GEN thread
superpro-beam-axle-pivot-bushing-fits-a32
MaxLife17
Jun 27, 2019 01:37 PM
