Increased noise in reverse on 2000 se
Hi guys,
Didn't really find anything on this. My max when put in reverse sound of engine increases. What I mean by that there is more deep noise inside a car. Stuff just shakes. When in in neutral or drive it is fine. You put in reverse and you got this deep deep rumble sound. Plastic starts to rattle. I don't know if this is a sound of bad pillow or what. Any input would be greatlly appreciated.
Could it be exhaust leak ?
I had the same problem. I originally thought it was a motor mount. The heat shield on the catalytic converter was loose and the heat shield around the pipe that connects to the rear exhaust manifold was completely rusted off. The shield was just lying against the pipe. It was in two pieces.
I secured the heat shield on the converter with a nut and bolt and removed the other heat shield that had rusted off.
TKHanson
11-24-2018 01:39 AM
Need help
23
10-02-2015 08:56 AM
