300zx calipers on 2002 maxima
Old Oct 10, 2013 | 10:50 PM
quietbone's Avatar
I have a 2002 Maxima and recently purchased a pair of 1990 ZX calipers and prepping them up for my car. I have 350 Z wheels on them if this helps to answer the question. I was wondering if anyone has installed ZX calipers on a 5th Gen and what size calipers and Brake lines did you buy for the Maxima?
Old Oct 13, 2013 | 12:16 AM
Peter_03Max's Avatar
It won't fit. You need custom brackets and 04 rotors to make it fit.
Old Oct 13, 2013 | 12:22 AM
http://www.mattblehm.com/300ZX_brakes.htm
Old Oct 13, 2013 | 01:33 AM
ShocknAwe's Avatar
honestly just get better rotors and brake pads, its easier and it will improve braking. 2002's have abs correct? If you have enough braking power to engage the ABS then you have enough brake torque
Old Oct 16, 2013 | 10:26 PM
quietbone's Avatar
They do have ABS. But what year rotors and what brackets did you get for your Maxima. I dont want to order any wrong parts online as I want to be certain I am getting the right parts for the modification.
Old Oct 16, 2013 | 10:28 PM
quietbone's Avatar
Originally Posted by Peter_03Max
I have been to Mattblem and have contacted him several times for questions and to purchase parts from him but have not heard from him as of yet. Anyone know if he is on Maxima.org?
Old Oct 17, 2013 | 07:45 AM
NmexMAX's Avatar
dot dot dot ...
He sold the business.
Go with A34 brakes, or the EVO brakes. I've had A34 brakes for a ton of years and they easily outperform the OEM brakes.
And don't as me about them, nor post a new thread, search. There's an awesome thread on it.
A34 = 6th gen brakes.
In short, they're totally bolt on.
Old Oct 17, 2013 | 09:49 AM
trinistallion19's Avatar
You can get the brackets to bolt the 300zx calipers from fastbrakes. Com
Old Oct 17, 2013 | 10:55 AM
Can you confirm 2005 maxima's calipers & rotors are direct bolt on for 2003? Are there any different between the two system? What about 06-08 calipers? They tell me it a different part numbers.
Old Oct 17, 2013 | 01:24 PM
Gemner's Avatar
All the information you need is at this link
Old Oct 17, 2013 | 01:39 PM
NmexMAX's Avatar
dot dot dot ...
04-08 calipers will bolt right on, as will the rotors and you can use your existing brake lines.
Search and you can find out more.
Old Oct 17, 2013 | 04:52 PM
SSJRICH's Avatar
Just did mine last weekend. Its by far the best "affordable" brake upgrade.
Got reman calipers with bracket, kept factory brake line, and got Power slot rotors with Hawk HPS pads. Got them seeded in good now and they are amazing. Definitely what you want for "spirited" driving. And its all bolt in.
Old Oct 17, 2013 | 10:36 PM
What about the rear? Are the 6th Gen max a direct bolt on?
Old Oct 18, 2013 | 07:39 AM
Gemner's Avatar
I hope nobody answers that because if you are incapable of using any search function you are definitely going to screw up a brake upgrade, crash, and kill a family of 6 with two newborns.
Old Oct 18, 2013 | 07:45 AM
quietbone's Avatar
Seriously dude? I have done extensive search on this process and found inconclusive and vague information on how the process is done. That's the only reason I opened this thread in order to find the most accurate information from fellow Maxima owners who have done the same process. For your information, I do know how to use google search and I am also college educated in case you are wondering. Stop judging people beforehand.
Old Oct 18, 2013 | 08:02 AM
Gemner's Avatar
information on BOTH the 6th gen and the 300zx swap is everywhere, there are even writeups on here for both. Its possible you didnt find anything because there are hundreds of threads like this one of people hoping someone else will do the work for them or just happens to have a link saved. There are many ways to hone your google-fu
FYI I wasnt wondering if you were educated at all
Old Oct 18, 2013 | 08:33 AM
L_U_D_I_AMaxima's Avatar
the best upgrade I have ever done on my car...
Old Oct 18, 2013 | 11:34 AM
Screw you! Peoples come here for answers and if you can't provide any help STFU! Dumbass!!
****off!!
Old Oct 18, 2013 | 12:14 PM
Gemner's Avatar
****off!!
Old Oct 20, 2013 | 08:45 AM
AznRyan's Avatar
Old Oct 21, 2013 | 02:13 AM
quietbone's Avatar
I was referring to THE 5TH gen Maxima not the 6TH gen mate. Cheers for helping.
Thanks Peter_03Max for your comment. Its not worth skirmishing with such people.
Old Oct 21, 2013 | 07:19 AM
AznRyan's Avatar
The 6th gen calipers swapped to a 5th gen. It was spoonfed to you that they would bolt right on, and you're still asking questions that have been answered.
Nintensity
Aug 13, 2015 05:41 PM
fastcarny
Aug 12, 2015 03:50 PM
papo99
Aug 9, 2015 07:24 AM
yat70458
Aug 3, 2015 01:16 PM
