New engine noise
Old Jan 17, 2002 | 03:12 PM
RayRey21's Avatar
New engine noise
i've noticed recently that when i hit the gas at highway speeds i can here my valves tick or ping. This all started after i took out my stillen intake and i'm not sure why this is happening. any ideas??
thanks in advance
Old Jan 17, 2002 | 07:05 PM
BigDogJonx's Avatar
Re: New engine noise
thanks in advance
Im not sure if someone mentioned this to you or not, but the ECU is adjusting the timing, which is causing the valve knocks.
Best thing to do, if you have not done it already is Unplug the negative cable from the batter overnight, not just 1hr, overnight. That will reset the ECU and will allow it to RElearn everything and should possibly fix the timing issue.
Dixit
Old Jan 17, 2002 | 07:48 PM
RayRey21's Avatar
Re: Re: New engine noise
i disconnected the negative cable and left it overnight and the problem was still there. what should i do next??
thanks
Old Jan 17, 2002 | 07:52 PM
95emeraldgxe's Avatar
its still on warranty!!!!! - take it to da dealer - dUH!
Bonka
Sep 14, 2015 11:18 PM
thenewguyy
Sep 12, 2015 11:12 AM
ballerchris510
Sep 11, 2015 05:29 PM
bennuss
Sep 11, 2015 05:55 AM
jfl330
Sep 4, 2015 01:44 PM
