Maxima getting hot the eventually overheating.
Old Dec 6, 2013 | 02:27 PM
thecookinpot's Avatar
Okay, here's the problem I have a 2000 Nissan Maxima, I'm on a trip to Florida from New York, It drove fine up until Florida then it started acting up getting hot and eventually overheating, I changed the thermostat and the radiator cap, the problem still continued then I took it to the mechanic and he flushed and purged it and said he checked the water pump and it was fine, I drove it around today the problem continues. There are no visible leaks no white smoke, it happens after driving above 50 for about 15-20 miles, all the fans are running, I just don't understand what the problem might be, anyone have ideas?
Attached Thumbnails Maxima getting hot the eventually overheating.-overheat.jpg
Old Dec 6, 2013 | 02:37 PM
Also I forgot to mention the heater blows hot, and the a/c blows cold.
Old Dec 6, 2013 | 04:20 PM
anyone?
Old Dec 6, 2013 | 06:29 PM
DjHackStyle's Avatar
Clogged radiator and u probably used an aftermarket thermostat which for some reason don't work on these cars
Old Dec 6, 2013 | 06:41 PM
Donkeypunch's Avatar
Just happens out of the blue?
Was the a/c on the times this happened?
At freeway speeds?
Old Dec 6, 2013 | 06:43 PM
chrome91's Avatar
i would suspect headgasket or cracked cylinder, would be worth getting the system tested for a bad headgasket
Old Dec 6, 2013 | 07:35 PM
foodmanry's Avatar
Da Roller Coaster!
Partially clogged radiator. Replace radiator and get OEM thermostat and you'll de fine.
Lakersallday24
Nov 7, 2024 07:31 PM
Smiley101
Aug 1, 2024 08:02 AM
acw
Aug 13, 2015 12:50 AM
altome15
Aug 10, 2015 07:05 PM
Gsantos79
Aug 8, 2015 07:41 AM
