...Sway Bars
Old 12-17-2013, 06:35 PM
Kevin Ellis's Avatar
...Sway Bars
Is there a difference btwn SE and GLE front sway bars...and if so which is better?
Kevin Ellis is offline
Old 12-17-2013, 07:06 PM
george__'s Avatar
Are you talking about the sway bar end links?
They are the same but the bushing sizes are different
george__ is offline
Old 12-17-2013, 07:24 PM
DennisMik's Avatar
The SE has a different sway bar from the one used in the GXE and the GLE. The SE bar is thicker for a slightly firmer ride.
It's your personal preference which one you think is better.
DennisMik is offline
Old 12-17-2013, 07:31 PM
George,
I'm sorry..I meant the front sway bar itself..not the links..but thanks
Old 12-17-2013, 07:34 PM
george__'s Avatar
Wouldn't that be a lot of work to swap out?
Would Stiffer springs or coilovers work?
george__ is offline
Old 12-17-2013, 07:35 PM
Dennis,
Thanks..thas the info I needed ...I'm putting some G35..18's and I was looking for a tighter and firmer ride ...I was thinkn to change the bushings, but I had a hunch the sway bar would better from a SE...I have a 01..can I use a sway bar from a 02 - 03?
Kevin
Old 12-17-2013, 07:56 PM
coolsun's Avatar
that 1mm thickness doesnt make much of a difference, just get the poly urethane bushings for them and you are good to go.
coolsun is offline
Old 12-18-2013, 07:31 PM
Coolsun,
If I get the SE sway bar..do I need SE end links or can I use the GLE end links and what bushings (name brand) would you recommend
Kevin
Old 12-19-2013, 07:12 AM
dot dot dot ...
NmexMAX's Avatar
It's far too much time to switch the front sway bar to an SE unit. I would just get the Poly Bushings (ES bushings) for the model of your car.
End links are the same. I would go with Moog end links, although I went with OEM. In any case, spend your time elsewhere other than switch a 1mm (less than 0.040" of an inch) thicker sway bar.
NmexMAX is offline
Old 12-19-2013, 03:23 PM
NmexMax,
Thanks, your right..I will focus on some mods, but I'm still getting the G35 rims
Thanks everyone for answering
06-06-2017 02:01 PM
gman214
09-25-2015 03:03 PM
followthadollar
09-23-2015 08:31 PM
Stagnet04
09-14-2015 11:28 PM
Quick Reply: ...Sway Bars
