Radio Install Question
Old Dec 28, 2013 | 01:10 PM
Cardonaj70's Avatar
I am new here but have a couple of questions about installing a radio. So i want to know if the amp in the trunk is only hooked up to the speaker in the back or to all the speakers.
Old Dec 28, 2013 | 01:36 PM
tosheto's Avatar
Not sure which year Maxima you are talking about, but it should be just hooked up to the back speaker.
Old Dec 28, 2013 | 01:51 PM
Cardonaj70's Avatar
Whoops sorry its a 2001 Maxima GLE.
Old Dec 28, 2013 | 01:52 PM
DennisMik's Avatar
If you have an amp in the trunk, you have a Bose system. And the Bose amp has all the speakers going through it. The Bose amp amplifies all the door speakers, but not the woofer. The amp does create the woofer signal and the woofer has its own amplifier.
Old Dec 28, 2013 | 03:47 PM
Cardonaj70's Avatar
Ok. Would i be able to directly hook a radio up by splicing the wires up front. If i could do you know the colors codes? Thanks in advance
Old Dec 28, 2013 | 04:20 PM
maximaminimum's Avatar
When soldering your stuff up front you should match colors to colors, and there is one or two unused the wires and they are for steering wheel controls which will most likely not be used anymore unless you bought the specific steering wheel control adapter part.
Old Dec 28, 2013 | 04:27 PM
Cardonaj70's Avatar
ok. Do you know the color codes for which speaker is which? Cause i cant find any that match up with my wire colors.
Old Dec 28, 2013 | 09:15 PM
JWatZ's Avatar
Why not buy a harness? Makes the job a heck of a lot easier.
Old Dec 28, 2013 | 09:19 PM
DennisMik's Avatar
To start with, the radio you bought should come with a wire harness that plugs into the radio and you need to solder wires to it. This wire colors in this harness are used by just about all manufacturers.
You should buy an adapter harness that will plug into the Maxima's wire harness and this is what you solder the radio's harness to. The brand Metra is the most commonly available adapter, their part # is 70-7551.
http://www.metraonline.com/vfg
Code:
Adapter Wiring for 2001 Bose Radio
                   After-market       Metra              Nissan Wire
Signal             Radio Harness      Nissan Adaptor     Harness, Bose        Pin #
Ground             Black              Black              black                  9
Ground             Black              Black              black                 11
Radio power        Red                Red                purple                10
Station Memory     Yellow             Yellow             yellow                 6
Antenna            Blue               Blue               green/white stripe     5
LF Speaker pos     White              White              white stripe           2
LF Speaker neg     White/blk stripe   White/blk stripe   Black                  1
RF Speaker pos     Gray               Gray               Green                  4
RF Speaker neg     Gray/blk stripe    Gray/blk stripe    Red                    3
LR Speaker pos     Green              Green              Brown                 14
LR Speaker neg     Green/blk stripe   Green/blk stripe   black/red stripe      13
RR Speaker pos     Purple             Violet             Blue                  16
RR Speaker neg     Purple/blk stripe  Violet/blk Stripe  black/white stripe    15
Remote Amp On      Blue/wht stripe    Blue/wht stripe    green/white stripe    12
Illumination       Orange/wht stripe  Orange             Red/whire stripe       8
Dimmer                                Orange/blk stripe  Red/yellow stripe      7
The colors listed for the Metra Nissan adaptor are for an after-market adaptor and
are NOT the color of the Nissan wiring harness.
The Nissan wire harness for Bose uses 2 connectors for the radio, M62 and M61.
M62 contains wires numbered 1 through 10 and M61 has wires numbered 11 through 16.
Old Dec 29, 2013 | 08:25 AM
Cardonaj70's Avatar
Thanks i figured it out now.
Old Jan 8, 2014 | 09:48 PM
ctsmith39's Avatar
if you have a bose system you might run into the issue of only having one cable for the front left speakers. I had that issue and when i toned it out i was missing my woofer cable. Not sure how it got signal but had to run new wire. Running new wire on the GLE's with the bose system is not fun.
Old Jan 9, 2014 | 08:57 AM
jontyrees's Avatar
Ah, good to know that little amps attached to each speaker is a Bose myth.
Where are the two amps located?
Old Jan 9, 2014 | 01:33 PM
djfrestyl's Avatar
Suspension Yoda
Not fully accurate. The 4th gen Maxima has an amp in each door that powers that speaker in the door.
In the 5th gen, the speaker amp is in the trunk, mounted upside down to the rear deck. The woofer amp is on the woofer itself, which is also mounted to the rear deck. Makes it looks like the woofer has a large magnet.
Old Jan 9, 2014 | 01:51 PM
jontyrees's Avatar
Good to know. Are there any ***** on the amps? Gains perhaps? I'm guessing the output is pretty low - think it's even as high as 15wpc? A 2004 Pontiac GTO I owned for a while had a stock amp for rear 6x9 subs that actually had a gain **** on it if you reached around the back of it.
Old Jan 9, 2014 | 01:53 PM
djfrestyl's Avatar
Suspension Yoda
No configurations whatsoever on the amps. All done through the HU.
IF installed correctly, an aftermarket HU WILL make your Bose system sound better.
Old Jan 9, 2014 | 02:36 PM
The_Fixer's Avatar
^^^ what he says just make sure you get the correct factory integration wiring harness for the BOSE system.
Old Jan 9, 2014 | 02:50 PM
djfrestyl's Avatar
Suspension Yoda
Or Line Output Converter. Depends on preout voltage of the HU selected.
Old Jan 9, 2014 | 04:45 PM
The_Fixer's Avatar
Also depends on what those factory amps can accept to high a output and it will clip to low an output and it wont have clarity.best way to figure it out is measure the output from the factory unit.but then again the highest output i have seen on a aftermarket is 8v output on line-level.
Old Jan 10, 2014 | 05:38 AM
djfrestyl's Avatar
Suspension Yoda
I use 4v as threshold.
4v or less = You need an LOC
Higher than 4v = use Metra 70-7551.
Maxinesdaddy
Aug 21, 2015 11:43 PM
carguy96
29
Aug 21, 2015 02:43 PM
MikesChevelle
Aug 9, 2015 11:50 AM
