Annoying pop that i can not figure out and has been there for years...
Old Feb 27, 2014 | 07:21 AM
blue_strip's Avatar
So I have a popping sound in the front of my max that has been giving me and my dad grief for years, we cannot figure out what is causing it, it sounds like a suspension or cv axle but it's not, it's not the linkage, steering rack, lower control arm, or the strut mount, has anyone else ever had this problem? If so did you figure it out, or is this a 5.5 gen issue
Old Feb 27, 2014 | 09:26 AM
2damax's Avatar
You are going to need to give these guys some information. When does it pop, any work previous to popping, any work since popping, mileage, anything
Old Feb 27, 2014 | 09:34 AM
blue_strip's Avatar
It has 180,600 miles, I've tried fixing it with all the previous repairs
Old Feb 27, 2014 | 09:47 AM
2damax's Avatar
Motor mounts ever replaced? If you search this is a common issue.
Old Feb 27, 2014 | 09:50 AM
blue_strip's Avatar
Are there any other symptoms for meet mounts?
Old Feb 27, 2014 | 10:20 AM
clintb3astwood's Avatar
Have you ever checked the passengers side mount?
Old Feb 27, 2014 | 10:31 AM
blue_strip's Avatar
I have not checked either, if I were to do this myself, would I need an engine hoist
Old Feb 27, 2014 | 10:41 AM
When does the popping noise start? During driving? Braking, shifting between gears? you can physically look at the side mount and see if its no good. If the rubber is cracked and loose its time to change. What springs are are you on? Have they ever been changed? Does the noise occur during turns or straight away driving.
Old Feb 27, 2014 | 11:08 AM
blue_strip's Avatar
so all three mounts have been replaced, original stock springs, have not had issues with them, it happens when i turn, which sounds like a cv axle issue, but the cv is fine, recently replaced the lower control arm, sway bar linkage, and no fix to the pop
Old Feb 27, 2014 | 11:34 AM
zero2sixtyZ's Avatar
You embarrass me.
I'd say strut mount bearing or spindle bump stop would be my first places to look.
Old Feb 27, 2014 | 11:37 AM
blue_strip's Avatar
I change my mounts and struts at the same time and I haven't been having a grinding sound when I turn, just sounds like when you crack a knuckle
Old Feb 27, 2014 | 11:46 AM
nsnrider's Avatar
Originally Posted by zero2sixtyZ
... spindle bump stop would be my first places to look.
+1. Make sure you have the plastic end cap on the bump stop.
Old Feb 27, 2014 | 11:53 AM
blue_strip's Avatar
Ok, would motor mounts also attribute to torque steer?
Old Feb 27, 2014 | 12:24 PM
blue_strip's Avatar
Just checked motor mounts, all is well, but I have a torn cv... So that solves the turning pop, but would a torn cv also cause torque steer?
Old Feb 27, 2014 | 09:15 PM
maxiiiboy's Avatar
Check the Right Engine Mount
No, you don't need an engine hoist.
If you haven't replaced your passenger side engine mount, chances are that's the problem. It's common, and my experience is very similar to yours. My mount gave multiple symptoms (clunking + lisping/grinding noise).
It's not expensive to repair. I can recommend Anchor mount (from RockAuto.com). Most mechanics can replace it in 20 minutes (but will charge you for more). It's doable DIY.
Old Feb 27, 2014 | 09:20 PM
blue_strip's Avatar
The passenger side looked perfect, I'll replace the cv this weekend, and go from there
Old Feb 28, 2014 | 04:46 PM
Donkeypunch's Avatar
motor mounts
Old Feb 28, 2014 | 05:08 PM
blue_strip's Avatar
They check out ok, no cracks or breaks...
Old Mar 1, 2014 | 02:30 PM
You take them off to check?
Mahmuth
Aug 16, 2024 08:23 PM
tarun900
19
Dec 20, 2021 06:57 PM
D Mason
Jun 21, 2016 04:43 AM
mpbclutch33
Dec 26, 2015 11:11 AM
fx4five
Oct 18, 2015 06:57 PM
