power steering leak
Old Jun 25, 2014 | 06:55 PM
BxMuLTiFLoW's Avatar
power steering leak
wassup guys so i was wondering if i have a leak on the top part of the hose and my powersteering fluid is low can it be more then just the hose i have to fix or is it just the hose ?
Old Jun 25, 2014 | 07:15 PM
cornholio's Avatar
most likely just the hose
http://forums.maxima.org/5th-generat...hose-02-a.html
pretty common issue
lots of people swear by oem, i'm using aftermarket and can't hear any of the noise most complain about.
Old Jun 25, 2014 | 08:39 PM
MONTE 01&97 SE's Avatar
pretty common issue
You got lucky, non Oem P.S hoses from my experience on Z's and Maxima's which is a lot usually lead to P.S noises!
Old Jun 25, 2014 | 08:57 PM
NC5thGen's Avatar
Just replaced my ps pump, after I cleaned up everything and drove a little I notice the high pressure hose was a little wet, so that could have been my issue from the start. I'm going to consider using a non oem hose.
Old Jun 25, 2014 | 09:46 PM
cornholio's Avatar
i at least knew there might be an issue before deciding to go the cheap route, it worked out ok
Old Jun 26, 2014 | 09:00 AM
e.esco's Avatar
cant disagree with you. i just replaced my power steering hose and it always kinda sounds like it has no fluid. im thinking about replacing it with oem. i hate that noise.
Old Jun 26, 2014 | 04:09 PM
Johnny7280's Avatar
This has happened to both my maxima's. First my 2002 and now my 2001. It's a super common issue especially once you're over 120k. I replaced my hose with the powercraft hose from advance auto parts for $120 bucks. Everything works fine and on mine there is no power steering noise at all.
Old Jun 26, 2014 | 07:53 PM
mrsandman's Avatar
OEM is the way to go.
Old Jun 27, 2014 | 12:05 AM
CMax03's Avatar
Go OEM or GO Home!!!!!! The reason why our P/s high pressure hose fails is because Nissan reduced the size of our p/s oil cooler compared to that of the 4th gen! The 4th Gen should fit or you could always go with a Permacool p/s cooler!
Old Jun 27, 2014 | 09:18 AM
ok so lets say i need to drive with the issue like that how long would i be able to drive until something else gets messed up??
Old Jun 27, 2014 | 02:14 PM
cornholio's Avatar
i drove with mine bad for a little while but only short trips, checked my fluid level every time i got in and topped off as needed. i imagine if it goes dry and you keep on it you'll end up replacing your ps pump as well.
Old Jun 28, 2014 | 09:51 AM
panabiker's Avatar
My 2002 also had the problem. It deteriorated quite fast because of the high pressure fluid. From the time I realized the leak because of the steering noise, to the time I had to add fluid every time I drove back and forth to work was about 2 weeks. It cost me $360 to have it replaced at an independent garage.
Old Jun 28, 2014 | 02:48 PM
Donkeypunch's Avatar
We have PS coolors?!
thx.
Old Jun 30, 2014 | 01:00 PM
Thorzdad's Avatar
thx.
Nope.
Old Jun 30, 2014 | 03:06 PM
Maxgig's Avatar
I wouldn't drive with the leak too long. If the hose fails suddenly you will have to detail your engine because there will be p/s fluid everywhere.
Old Jun 30, 2014 | 03:33 PM
tosheto's Avatar
I replaced mine with one from rockauto and did not have any problems, but maybe I was just lucky. Good luck OP.
Old Jul 23, 2014 | 11:13 AM
russ29's Avatar
please provide a picture of the suspected failing hose. I also have a PS leak but have not been able to find the source.
Old Jul 24, 2014 | 11:30 AM
russ29's Avatar
Rock Auto hose
Which hose did you get? I see there are 4 or 5 choices...
lowpost99
Oct 26, 2025 06:53 PM
Mar 12, 2020 12:06 AM
2kmaximel
Sep 10, 2015 08:13 AM
ag90fox
Sep 9, 2015 12:22 PM
SusieQQ
Sep 9, 2015 12:14 PM
