Electronic Whining sound coming from up front? 2001 AT
Old Jul 2, 2014 | 03:18 PM
AT978's Avatar
I haven't had my max for very long but every time I start the car, shift into reverse, drive, park, come to a stop, and turn the engine off. It makes this electronic whining sound for a few seconds. It's a 2001AE it doesn't do anything to performance, just really annoying cuz everyone always looks with a weird look. Any ideas?
Old Jul 2, 2014 | 09:45 PM
WTF?'s Avatar
HMMM....bad fan? Maybe takes a second to spin down, and making a little noise in the process? Pop the hood, and have a hot chick turn the car off while you look. Maybe you can spot something. I don't really know of anything else under the hood that would be spinning once the engine is killed.
Seriously,.....the chicks gotta be hot, or it won't work right.
Old Jul 2, 2014 | 09:54 PM
AT978's Avatar
Hahahah hot chick, but in all seriousness, I've looked and the only think spinning is the radiator fan, but I don't get why it has such a bad sound to it.
Old Jul 2, 2014 | 10:57 PM
NC5thGen's Avatar
So basically while your driving do you hear the sound? Alternator maybe
Old Jul 2, 2014 | 11:52 PM
AT978's Avatar
Does the alternator take a bit to come to a stop? Like after the engine is shut off
Old Jul 3, 2014 | 01:25 AM
SpeedCrazie's Avatar
Electronic motor mounts going bad. Unplug before it fries the ECU.
Old Jul 3, 2014 | 06:35 AM
cornholio's Avatar
sounds like mounts to me too. pick up a set of manual mounts and swap them out
Old Jul 3, 2014 | 07:21 AM
Nuffstylez's Avatar
yep, sounds like the mounts. disconnect it asap
Old Jul 3, 2014 | 09:46 AM
CMax03's Avatar
Yeah those are you motor mounts...it has a servo like sound! They don't need to be plugged up...just unplug and forget about them!
Old Jul 3, 2014 | 10:13 AM
AT978's Avatar
Where are they located and what do they look like? Why would it make that kind of noise?
Old Jul 3, 2014 | 10:36 AM
cornholio's Avatar
http://forums.maxima.org/8964162-post10.html
they make noise because they're going bad, auto mounts have some sort of magic jelly that makes them stiff while driving and soft when sitting still to minimize vibration. if you leaked your goo and they arent stiff anymore just buy manual ones for cheap ($100ish) and use those as a replacement.
if you still have a noise after you disconnect them then they're not the problem tho
Old Jul 3, 2014 | 10:58 AM
AT978's Avatar
if I unplug them and don't replace them what's the worst that can happen
Old Jul 3, 2014 | 11:12 AM
cornholio's Avatar
the worst that can happen is your engine will fall out of the bottom of your car sending you skidding into a schoolbus and everyone dies in a huge ball of fire
but i think the most likely scenario is your engine moves a lot under the hood and the throttle feels less responsive as a result
maybe someone who knows more about this will chime in
Old Jul 3, 2014 | 11:44 AM
AT978's Avatar
Oh, also, if I unplug it and plug it back in, is there a chance that the ecu will freak out?
Old Jul 3, 2014 | 11:50 AM
Fakie J Farkerton's Avatar
Don't plug them back in. Ever.
Old Jul 3, 2014 | 11:57 AM
AT978's Avatar
So lose them unless I get replacements is what you're saying?
Old Jul 3, 2014 | 05:00 PM
Donkeypunch's Avatar
Mine has a buzz too but the mounts are not connected.
Old Jul 3, 2014 | 07:25 PM
Quickywd01's Avatar
You will be sorry if you don't listen to the folks that are telling you to unplug and leave them unplugged. The mount stiffens up when it gets a signal that's all and nothing will happen if you unplug them. Save yourself while you still can.
Old Jul 3, 2014 | 07:33 PM
cornholio's Avatar
yes, unless you want to replace your ecm one day too
imo auto replacements are not worth the money. manual work fine, are cheaper and dont put the ecm at risk.
Old Jul 3, 2014 | 09:16 PM
DennisMik's Avatar
When you unplug the motor mounts, have the engine running at 1K rpm. This puts the mount in firm mode.
Old Jul 4, 2014 | 10:54 AM
AT978's Avatar
I see where they are located but how am I suppose to replace them? I can't see where the actual mount is located just the wire
Old Jul 4, 2014 | 02:00 PM
cornholio's Avatar
the mounts you need are on top of the crossmember below the engine, there are some good written instructions and also some pictures in this thread here:
http://forums.maxima.org/5th-generat...-opinions.html
Old Jul 4, 2014 | 04:28 PM
AT978's Avatar
I'll probably have to get a mechanic to swap them out for me... Sigh... Time to go tell mom about this
MikesChevelle
Aug 9, 2015 11:50 AM
kirkhilles
Aug 8, 2015 10:53 AM
follyburr
Aug 7, 2015 09:50 PM
BassAddictJ
Aug 4, 2015 11:38 AM
Jcof88
Aug 3, 2015 10:43 PM
