Won't Idle- stalls after IVAC and ECU repair
Old Oct 14, 2014 | 06:49 PM
blackmax42's Avatar
2001 AE Manual Transmission-
Car started and idled fine the first time... even dropped idle a bit when warmed up. Much rejoicing.
Next startup and always now, it will stall- won't idle at all. Much despair.
1. Do I have to do the idle idle relearn after IVAC and ECU replacement? (also cleaned throttle body)
2. Can I just unplug battery for a few days which I understand is the ECU reset?
3. What else MUST be done after this procedure?
note: I think the idle relearn procedure depends on the car being able to idle right?
Old Oct 15, 2014 | 09:38 AM
00Lightsout's Avatar
check your fuel pump and injector fuses under the dash.
pull the MAF and clean It with the proper MAF cleaner from CRC
I would get it started and apply the accelerator just enough to keep it running till it's up to temp.... see if it holds then.
Old Apr 7, 2016 | 06:55 PM
beechmon's Avatar
Any updates?
mkaresh
Mar 12, 2018 06:48 PM
gigabyte
Jan 6, 2017 06:05 PM
MichMaxFan
Sep 30, 2015 09:18 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
