Help - before I get raped at the dealership!
Old Oct 26, 2014 | 05:14 PM
  #41
jsmith24's Avatar
Originally Posted by colt149
Hook up your vehicle to OBD scan tool with live feed to check for error code and impending error code.
Unfortunately, the only scan tool I have access to is at Autozone, and they said without the CEL/SES light, there's no code for them to read. Thanks, though.
Jack
Old Oct 26, 2014 | 05:52 PM
  #42
Lontar1's Avatar
Puerto Rico-Maxima Lover
Jsmith, where are you located, if you are close to Philly I will go and check your car for free......
Old Oct 26, 2014 | 06:06 PM
  #43
george__'s Avatar
Meeting strangers off the internet
Old Oct 26, 2014 | 06:07 PM
  #44
colt149's Avatar
Without the OBD scan tool with live feed. , you are fixing blindly.
Old Oct 26, 2014 | 06:08 PM
  #45
Lontar1's Avatar
Nice one......lmao
Old Oct 26, 2014 | 06:09 PM
  #46
Lontar1's Avatar
I have one....
Old Oct 26, 2014 | 06:20 PM
  #47
jsmith24's Avatar
I appreciate the offer, Lontar1, but I'm in Richmond, Virginia.
(Neat trick, though, luring people with your free OBD scans... )
Thanks!
Old Oct 26, 2014 | 06:27 PM
  #48
Lontar1's Avatar
Thanks!
Ill be in Richmond on Nov 21 to work on a friends car for a few hours, then drive down to Florida, if you still have the issue then, let me know and Ill check it out.
Old Oct 26, 2014 | 06:47 PM
  #49
jsmith24's Avatar
That's awesome. I'll let you know, and thanks for the offer. That's why I love the .ORG and her members!
Jack
Old Oct 26, 2014 | 06:57 PM
  #50
george__'s Avatar
Take some pictures !!
Old Oct 26, 2014 | 06:59 PM
  #51
jsmith24's Avatar
Of what, George?
Old Oct 26, 2014 | 07:01 PM
  #52
george__'s Avatar
Of what, George?
Your cars
Old Oct 26, 2014 | 07:03 PM
  #53
jsmith24's Avatar
Your cars
Oh, sure thing, but mine is a daily driver, two kids, 255k+ miles, not a show stopper.
Old Oct 26, 2014 | 07:11 PM
  #54
george__'s Avatar
That's the job of the Maxima, it's your 4 DOOR SPORTS CAR.
Old Oct 26, 2014 | 08:44 PM
  #55
clintb3astwood's Avatar
sounds like the alternator
Old Oct 26, 2014 | 09:45 PM
  #56
DennisMik's Avatar
The op (jsmith24) checked voltage back in post # 39 and has 14.3 volts. The alternator is OK.
I have to join forces with those that suspect the MAF.
Old Oct 26, 2014 | 10:04 PM
  #57
johnlim123's Avatar
I would also check the alternator, i have had my max 2003 stall on me too while pulling out and barely made it home, replaced in under warranty and its all good now...CEL never came on nor the battery sign, and when i returned it pepboys says no problem with it..it did have a lot of oil on from a leaking valve cover gasket..seems to have been an intermittent issue with alternator. 1000 miles and no problems now..
Old Oct 27, 2014 | 12:17 AM
  #58
Leo_Koneval's Avatar
When your MAF starts going out, you won't throw codes. Mine sure did not until my car basically could not run anymore. I think I said that same thing in another post.
But how I diagnosed my MAF problem was unplug it. You are not at the point where I was, but basically my car had a really rough idle, the RPM would drop, car almost die, rev back up, and repeat. I unplugged the sensor and it smoothed out, plugged it back in and the rough idle came back.
Or you can get a fancy scan tool to read what your MAF is sending out. It was years ago but I think I looked at the air fuel ratio. I remember getting occasional crazy readings which would make my car die, every time it popped up.
But yeah, good luck.
Old Oct 27, 2014 | 05:26 AM
  #59
jsmith24's Avatar
Thanks, Leo. My idle is smooth, though I suspect at least on of my plugs needs to be replaced since I get a miss every now and then. Replacing the plugs is on my list, but I've never known a bad plug to cause full shutdown, so I came here. I'm going to try to get the MAF swapped out today. We'll see what happens!
Jack
Old Oct 27, 2014 | 05:48 AM
  #60
nestorlugo's Avatar
The crankshaft or cam sensor i forget which one ,cuts off fuel pump when it's below spec .
It seems that a gst should be the first thing you need to buy before you start throwing parts at her...if you don't have a fortune to splurge with.
Old Oct 27, 2014 | 07:12 AM
  #61
Lontar1's Avatar
Mine has also 250k+ miles, and it is a daily driver.........
Old Oct 27, 2014 | 09:04 AM
  #62
jsmith24's Avatar
I hate to show my ignorance once again, but what's a "gst"?
Old Oct 27, 2014 | 09:19 AM
  #63
jsmith24's Avatar
About to bite the bullet, got a MAF specific question: I see I can get the entire assembly for about $350, or just the sensor itself for just at $100. Do I HAVE to replace the whole assembly, or can I get only the sensor?
I wouldn't jump on it so quickly, except it's doing it more and more even today.
Thanks again,
Jack
Old Oct 27, 2014 | 09:36 AM
  #64
Lontar1's Avatar
Sensor only..... you have the housing already
Old Oct 27, 2014 | 09:44 AM
  #65
jsmith24's Avatar
That's what I figured, but Mother Nissan insists that, for some reason, the plastic housing must be replaced also. Oh, btw, local dealer said $529 for the assembly. Dang, I'm in the wrong line of work - I just need to open a Nissan OEM supply shop!
Old Oct 27, 2014 | 10:38 AM
  #66
nestorlugo's Avatar
Its a generic scan tool .
To remove the your sensor you'll need the security t20 torx allen key.
It wouldn't be a bad idea remove the plastic housing and power wash all the dust particles from inside once you've removed the sensor.
Old Oct 27, 2014 | 10:54 AM
  #67
Montego Murph's Avatar
One thing that hasn't come up yet which might be worth checking... How many keys do you have on your keychain? Do you have a mega-huge ball of keys or just the one? Just for kicks, if you have a huge keyring, try just the key by itself.
I've seen this on two cars already: Huge heavy keyring bounces around and over the years the tumbler wears out a little bit. Hit a big enough bump or shift a little harder than usual and the engine cuts out momentarily when the switch loses contact.
Just one more thing to check
Old Oct 27, 2014 | 11:10 AM
  #68
jsmith24's Avatar
Nestor Hugo - Thanks for the "GST" info. My sensor was just T-20, no security nipple. As for the plastic air box housing - oh yeah, as dirty as the outside of my car may be, whenever I take something apart it gets a thorough cleaning! I can't believe how much actual dirt, not dust was in there, along with huge leaves and three or four yellow-jacket wasps.
Montego Murph - I've always had just the one key. I actually thought about what you said when it first happened and tried to jiggle the key manually in all sorts of ways to see if I could get it to give a false "ignition off" reading, but it was fine.
Okay, well, just took it apart, cleaned the MAF, inner screen, air box, all that jazz, just gotta wait for the sensor to arrive now I guess and drive with the old one as best I can.
Thanks, gents - I'll let you know what happens.
Jack
Old Oct 27, 2014 | 11:11 AM
  #69
Rochester's Avatar
The difference between the 2001 MAF and the 2002-2003 MAF is a 79-cent termistor. I thought this was common knowledge in the 5th Gen forum.
I replaced my MAF sensor at 70K as a precautionary measure, way back when. Someone on the forum who did the research kindly mailed me the thermistor, and I soldered it into a 2001 MAF. Worked like a charm for my last year or two of ownership, and the two years of ownership for the next guy.
Old Oct 27, 2014 | 11:58 AM
  #70
Lontar1's Avatar
Oh trust me, you should..
Old Oct 29, 2014 | 05:55 PM
  #71
jsmith24's Avatar
Now, I'm not going to complain about my Maxima, because I've got one of the "blessed" ones. I got 240k miles on the original clutch (still worked fine when I replaced it, just being cautious), never had the recurring MAF sensor problems like some folks, or the broken timing chain guide or any of that (KNOCK ON WOOD), but get this - I ordered the new MAF yesterday, and ever since I clicked "Purchase", the car has behaved perfectly.
I may have stumbled onto some magical mechanics...You don't even have to install a part, just order it and *threaten* to install it!
Old Oct 29, 2014 | 07:09 PM
  #72
cornholio's Avatar
even if it now is behaving just consider the new MAF preventative maintenance. if your original lasted you 250k+ miles, your replacement should cover the rest of your ownership
Old Oct 29, 2014 | 07:48 PM
  #73
jsmith24's Avatar
Oh, I know. I was just contemplating the irony of it all. I *think* it's irony...
Either way, the part arrives tomorrow and gets swapped out. Just for kicks I'll reset the ECU and do the throttle learning procedure. Can't hurt, so...
Next month - plugs.
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
D Mason
Jun 21, 2016 04:43 AM
bigfrank
Oct 1, 2015 12:51 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
