Engine shaking. checked most of stuff.
Old Dec 19, 2014 | 05:07 PM
balu's Avatar
Got a 2003 max manual trans 190k. the engine shakes at idle and while driving. Got it for cheap in this condition figured i can fix it. Checked maf,plugs, coils,injectors, serpentine belts, ecm, compression, Cam sensors, throttle body, vvt solenoids, Motor mounts, and everything checked good. It feels like something is out of balance. Im out of ideas. Could a out of balance fly wheel or clutch cause this? I would check the timing but not so sure how to. I have ndsII and it shows timing at 13 to 15 degrees.
Old Dec 19, 2014 | 05:14 PM
chrome91's Avatar
any codes in the system?
Old Dec 19, 2014 | 07:53 PM
balu's Avatar
codes
had a p0018 cor the crankshaft position sensor cleared it a few days ago and no codes till now
Old Dec 20, 2014 | 01:35 AM
DennisMik's Avatar
I would think that an out of balance flywheel or clutch would make make the vibrations get worse as the rpm's increased.
When the car is idling, unplug either the coil or the fuel injector on each cylinder (one cylinder at a time) and see if the idle gets worse. If it doesn't, then you have found the problem cylinder and can focus on it. You can swap ignition coils, check the ohms of the fuel injector and maybe listen to the injector with a stethoscope.
Old Dec 20, 2014 | 03:38 PM
balu's Avatar
Checked all coils and injectors.
Thanks for the reply. I checked all coils one by one. Even bought 2 oem coils to make sure. Checked injectors as well. I pulled each injector to test pulse and spray pattern all is good. Checked and cleaned all the ground connections I knew off. Any help is appreciated.
Old Dec 20, 2014 | 04:16 PM
nestorlugo's Avatar
Subscribed!
This is the worst case senario.
or just george_ trolling.....
Old Dec 20, 2014 | 04:22 PM
balu's Avatar
idle rpm seem fine too.
When I hook up the ndsii to the ecm it shows idle speed at 650 rpm and the speed is stable but engine keeps shaking.
Old Dec 20, 2014 | 04:25 PM
nestorlugo's Avatar
Did you or someone else check the engine mounts?
Old Dec 20, 2014 | 05:15 PM
balu's Avatar
sure did check the mounts
The mounts are not in the greatest condition but they are functional.
Old Dec 20, 2014 | 06:34 PM
nestorlugo's Avatar
Flywheel , clutch
Old Dec 20, 2014 | 06:36 PM
george__'s Avatar
Old Dec 20, 2014 | 06:45 PM
maxiiiboy's Avatar
That's not good enough. Replace your engine mounts - preferably all four, unless you can determine which one(s) is bad. You can get all from a reputable site such as RockAuto.com for about $150.
(How do I know? - I had a very annoying clunking problem and my mechanic was telling me my mounts were OK. To make along story short - he was wrong, and the people on this forum who advised me to replace the mounts were right. This story seems to repeat itself quite often ..... ).
Old Dec 20, 2014 | 06:58 PM
balu's Avatar
will order the mounts
I will order the mounts tomorrow and if that doesn't fix it im planning on dropping the trans to check flywheel n clutch.
Old Dec 20, 2014 | 07:07 PM
george__'s Avatar
Consider getting Energy Suspension mounts for front/rear... Polyurethane so way stiffer and sell the front/rear here or wherever.
Old Dec 21, 2014 | 12:45 AM
balu's Avatar
Bad trans mount?
Ok so I used a metal bar to pry on the trans mount while the engine was running and the shaking literally stopped so Im thinking the problem may be the mounts indeed. Will update after I replace the mounts.
Old Dec 25, 2014 | 09:39 PM
balu's Avatar
Replaced mounts and the vibration is still there not as strong but present. Whats next?
Old Dec 26, 2014 | 02:53 PM
DennisMik's Avatar
You have at least one cylinder that is not creating as much power as the others. Find out which one by unplugging the ignition coils one at a time while the engine is idling. When you unplug a coil and the idle does not get any worse, you have found the cylinder that is not working properly.
Then you need to re-check the ignition coil, the fuel injector or compression for that cylinder.
sctludwig
Sep 1, 2022 01:32 PM
jfl330
Sep 4, 2015 01:44 PM
dcardello
Sep 3, 2015 11:44 PM
crazyespn
Sep 3, 2015 01:30 PM
A32goldylocks
Sep 2, 2015 06:39 AM
