Just bought a wrecked 2003 6spd, need some advise
Old 01-02-2015 | 06:15 PM
matts95max's Avatar
I should have spelled advice correctly. Oops.
So, I purchased a wrecked 2003 maxima with 165k miles. Its the 6-spd, has leather, its an SE model. The previous owner hydroplaned and hit a curb with the driver side wheel. The wheel is pushed way back into the back of the wheel well towards the firewall. Its tight up against the fender/wheel well. I think the lower control arm needs replaced but Im not sure what else. I plan to take it apart soon to see what it looks like. What all should I look at when I removed the wheel? What potentially could have been damaged?
Thanks,
Matt
Old 01-02-2015 | 06:30 PM
carsnwomen91's Avatar
bent axle? i guess anything else thats connected to the wheel. i'd be most worried about the axle
Old 01-02-2015 | 11:53 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Junkyard - buy the knuckle, control arm, strut/spring (if you're staying stock) and axle. Maybe they have a rim laying around, too.
Obviously, taking off the control arm and knuckle in one piece is easy for removal and reinstallation. This is a fast and easy repair once the old parts are off.
You might as well do headers while you're working on it. Save the motor.
I would compliment this with a UDP to scrap the pos stock pulley and replace the front seal. Also, 6th gen valve covers while you're at the junkyard (or w/e newer VQ car). Hell, you might as well grab the 6th gen rotors and calipers while you're at it.
multiple edits b/c I can't read...
Old 01-03-2015 | 09:06 AM
schmellyfart's Avatar
Steering rack, tie rods, sway bar, axles, control arm, knuckle, strut, trans, engine mounts could have all been damaged.
Old 01-03-2015 | 12:02 PM
Bad *** Newb
I forgot tie rods lol
edit: and that stupid end link. Hopefully, it broke easily, so sway bar is alright.
Old 01-03-2015 | 12:12 PM
chrome91's Avatar
pretty much sums it up. may as well get a whole assembly from a scrap or junkyard car
Old 01-03-2015 | 01:50 PM
matts95max's Avatar
Man I hope the tranny is fine. I can deal with all the rest. I plan to start tearing it down Monday to see what I need. Thanks for the help!
Old 01-03-2015 | 02:01 PM
matts95max's Avatar
Here's a pic of the damage:
Old 01-03-2015 | 02:09 PM
chrome91's Avatar
yep basically what schmelly listed as well as wheel, fender, hood, headlight, possibly rad support
Old 01-03-2015 | 02:13 PM
Bad *** Newb
Damn, that's all easy swap stuff if you have a white maxi at the yard! You can probably swing a deal getting that many parts, too.
Old 01-03-2015 | 03:14 PM
clive's Avatar
100% chingon
After you fix it up put it on an alignment frame at a body shop to check that the monocoque isn't distorted.
Old 01-03-2015 | 04:45 PM
matts95max's Avatar
Thanks Clive, definitely didnt even consider that.
Max139617
10-19-2016 11:34 AM
VQ'ed
Forced Induction
02-29-2016 08:05 AM
KabirUTA13
19
10-17-2015 02:15 AM
220k+ A32
09-23-2015 03:38 PM
Violator
09-09-2015 10:14 AM
Quick Reply: Just bought a wrecked 2003 6spd, need some advise
