How to fix this?
Old May 1, 2015 | 11:34 AM
george__'s Avatar
How to fix this?
The rear passenger sidemarker sometimes doesn't turn on... Have to hit the bumper...
Checked the wiring and one of the bends is causing the issue. If I hold the bend straight it turns on 100% of the time but then I can't put it back into the car
any cheap fix?
Old May 1, 2015 | 11:38 AM
You found the problem, just fix it. Should cost less than $5 and 15 minutes of your time.
Use an exacto knife and split the wiring so that each wire is isolated. Repeat and bend wires again to determine which wire is bad. Cut out 4" length of bad section and splice in new section of wire.
Old May 1, 2015 | 11:41 AM
george__'s Avatar
What's good wire gauge?
can I use a computer ATX PSU wire?
Old May 1, 2015 | 11:44 AM
You're overthinking this.
As for wire gauge, just replace in kind.
Old May 1, 2015 | 11:56 AM
Derrick2k2SE's Avatar
You may even find that the wires aren't broken and there's just some worn insulation letting them short. In that case you can just tape the worn wires individually then wrap them all back up.
Like Wizard said. Use similar or thicker wire.
If you don't have extra wire and stuff like that laying around, you should check out your local U-pull it yard. You can get stuff like that for next to nothing.
Old May 1, 2015 | 12:01 PM
Old May 1, 2015 | 02:29 PM
george__'s Avatar
I think it might be the connector itself or somewhere higher up.
Oh well I'll hit the bumper every now and then
Old May 2, 2015 | 07:59 AM
King_Ten_Ahead's Avatar
Silence, I KEEL YOU
gigabyte
Jan 6, 2017 06:05 PM
D Mason
Jun 21, 2016 04:43 AM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
