Intermittent engine cutoff
Old Oct 29, 2015 | 08:56 AM
johnaschon's Avatar
The car runs normally and then with no warning cuts off. You can crank it back up but sometimes it takes 10 or 15 seconds of cranking but once cranked it again runs normally. Sometimes will go hundreds of miles between incidents some times 5 or 10.
Any Ideas?
Old Oct 29, 2015 | 10:14 AM
mclasser's Avatar
Year/mileage? The crank- and/or camshaft sensors could be bad. There was a recall for this several years back. Check for codes if the SES light's on.
Old Oct 29, 2015 | 12:07 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Yep, one of the cam sensors.
Old Oct 29, 2015 | 02:43 PM
maxiiiboy's Avatar
Any Ideas?
As suggested above by Mclasser and Child, it's one or both of your CAM and/or CRANK sensors. The sensor is failing intermittently. The failure episodes will become more and more frequent, until it fails hard. I would not wait .... just replace it. You can buy them at Rockauto.com for under forty dollars.
davidtemple
23
Jan 6, 2016 09:21 PM
Mahmuth
Dec 11, 2015 06:59 AM
brichi
Nov 1, 2015 06:40 AM
Crusher103
19
Oct 31, 2015 03:41 PM
rkspec
Oct 27, 2015 09:42 AM
