P0158/P0159 - No Emissions Req - Necessary?
Old Feb 16, 2016 | 06:37 AM
kirkhilles's Avatar
2001 i30 w/208k
I just got finished doing a long, drawn out fix for the P0505 issue. Replaced the Idle Controller, had the ECU replaced, did the coolant bypass, unplugged the active engine mounts, replaced the MAF and cleaned the TB (plus finally replaced the front struts/springs) and needed to replace my rear calipers (and associated pads/rotors) and now I'm getting the P0158/P0159 CEL codes. Grr!
The issue happened after about 100 miles of driving.
Years ago I got the P0420 code and then it went away.
So, here's what I want to know. This car is my backup, once-a-week car (drove today because it was icy out) and I'm trying to stretch it out for 2 more years until our SUV loan is paid off. I have no more energy or money to throw at this unless its a critical issue.
I live in the country, so I do NOT have emissions requirements. I do not care about MPGs and the value of the car is less than the parts/tires I've put on it.
So, given all of that, is there a strong reason to replace this? I'm still shaken up from the whole stalling drama that the P0505 did to me, so I want to make sure that the car will run otherwise. I can't handle another stalling incident.
Thoughts? I've spent some time searching, but I'm not seeing what I'm looking for. Feel free to give me links if this has been discussed.
Old Feb 16, 2016 | 07:00 AM
Derrick2k2SE's Avatar
The secondary (sensor2) o2 sensors are only there to monitor emissions so you should be fine.
The primary sensors (sensor1) give the ECU information to keep it in tune.
Old Feb 16, 2016 | 07:09 AM
kirkhilles's Avatar
Okay, cool, so, these are the secondary sensors right? I'll leave them alone then.
Thanks!
Old Feb 16, 2016 | 09:45 AM
The codes are triggered by the secondary sensors. Either the sensors are bad or they're picking up on elevated levels of pollutants. Either way you should be ok if the car is running fine.
13r1an
62
Jun 13, 2016 10:16 AM
2001i30
Apr 21, 2016 09:10 AM
gdurso
Jan 4, 2016 08:49 AM
RA121625
Dec 29, 2015 11:40 AM
Quantumxl
Dec 26, 2015 11:26 AM
