2003 fuel pump question!!!!!!!!!
Old Feb 21, 2016 | 06:25 PM
Sam Maxima's Avatar
Hi guys I have a question about fuel pump on my Maxima,I want to replace it just due to age and mileage not because it won't perform or anything,so my question is what's my best choice get the denso or walbro or what do you guys prefer/recommend and also what LPH should it be!
Thanks again guys.
Old Feb 21, 2016 | 07:10 PM
Roblee's Avatar
Denso is pretty good, but if it aint broke dont fix it. I'd leave it alone.
Old Feb 21, 2016 | 07:51 PM
Sam Maxima's Avatar
Ain't broke but I just want to prevent broke down car and I'm ocd when it comes down to my cars,is any others would chime in on this fuel pump deal?
But anyways thanks Roblee
Old Feb 21, 2016 | 08:27 PM
Mints33's Avatar
How many miles on the pump?
Old Feb 21, 2016 | 09:07 PM
Derrick2k2SE's Avatar
Honestly, I think it would be money wasted.
It's extremely rare for the fuel pumps on these cars to fail even after several hundred thousand miles. The pump from Ni$$an is expensive and I don't know if an aftermarket would be an upgrade or not.
I have two Maximas. One with 200,000 and the other with 300,000. Both are on the original pumps with no issues. The 300,000 mile car is still on the original filter.
Do a search here in the 5th gen forums. I doubt you'd find more than a handfull of failed fuel pump threads if even that. You'll find some where it's suspected but it always turns out to be something else.
If anything is going to leave you stranded it's going to be the MAF or one of the other sensors. Maybe the throttle body on an 02 or 03.
Old Feb 22, 2016 | 12:37 AM
Sam Maxima's Avatar
It has 245k on the clock
Old Feb 22, 2016 | 12:38 AM
Sam Maxima's Avatar
245k miles on the clock
Old Feb 22, 2016 | 12:40 AM
Sam Maxima's Avatar
And Derrick I did replace my fuel filter and current pump is quite and all but was just trying to prevent a broke down situation
Old Feb 22, 2016 | 07:00 AM
mclasser's Avatar
If you're looking to spend money, do it on more pertinent things. At 245K, your suspension and rubber components are probably done. When's the last time you did a tune up and changed all your fluids?
Keep an eye on the pattern failures with these cars -- seized calipers, HP PS hose, engine mounts that fry the ECU, radiator, etc.
Old Feb 22, 2016 | 07:49 AM
Sam Maxima's Avatar
Mclasser my both Maximas suspension is been replaced with upgraded bushings,tie rods,sway bar end links,plugs,water pump,tensioner,new upgraded alternator,new lights,new shocks/springs you name it I've done it my self-except fuel pump,�� But thanks for the recommendations though!And car runs like a champ but I am ocd with my cars,so that's why I was asking about the fuel pump so that way I now which brand maxima people prefer in our cars!
Old Feb 22, 2016 | 09:43 PM
JonBlz's Avatar
a.k.a. STuNtMAN
I replaced mines with a walbro fuel pump trimmed the 2 small towers on top since the 5.5 walbro won't fit unless you trim the towers, also threw in a fuel filter and I tell ya, the difference is night and day throttle, filter was black my 02 has 216k on body 40k on 08 engine and 0 miles on tranny.
Old Feb 23, 2016 | 04:54 AM
dwapenyi's Avatar
... I am ocd with my cars...
Not to aggravate your OCD or anything, but a regular diet of TC-W3 is good and will lubricate your entire fuel system, including the fuel pump and especially the injectors. It'll also make your car run quieter and smoother, not to mention restore your mpgs to OEM if your car feels a bit thirstier than normal.
Like I said, not to encourage your OCD or anything
https://maxima.org/forums/fluids-lub...itive-new.html
Old Feb 23, 2016 | 06:20 PM
Sam Maxima's Avatar
Good to know that,I'm just afraid that the walbro will make more pressure and that'll cause some issues like the old fpr getting tired and such!
Old Feb 23, 2016 | 06:22 PM
Sam Maxima's Avatar
Not at all man,but yeah I've been running the synthetic formula tc oil on few tanks-not every tank but I can't seems to get a clear answer reading through threads about the tc oil in gas?
Old Feb 24, 2016 | 01:36 AM
dwapenyi's Avatar
You have to keep in mind that the amount of TC you put in is fantastically small. For an 18 gallon tank, you put somewhere around 4 ounces into the tank. In other words, that 4 ounces is added to the 2304 ounces of fuel already been in the tank.
A worry I might have would be the long term effects on emissions, like the catalytic converters. If you read the many threads, you'll see that it has been tested for a long time. And, because it cleans up everything along the fuel lines, including the injectors, your car is running at its best, so it might actually make all your emissions stuff last longer.
Old Feb 24, 2016 | 01:59 AM
dwapenyi's Avatar
Old Feb 24, 2016 | 02:16 AM
Sam Maxima's Avatar
Yeah I've been using 3 ounces per fill up and like a said not every tank though-and my question is should I use it every tank or should I use it once every oil change?Thanks Dwapenyi
Old Feb 24, 2016 | 05:52 AM
dwapenyi's Avatar
Every tank. I've been lazy sometimes and skipped a few fillings. The effect wears off very slowly, so skipping a tank or 2 or 3 is no biggie.
Old Aug 19, 2025 | 11:02 AM
uptownsamcv's Avatar
I changed mine a few years ago when I hit 250,000 miles. I went with a Bosch, decent brand for a decent price. right now I'm at 368,XXX miles. what I also recommend is to change the pressure regulator in the fuel pump housing. the best way to make a fuel pump last is to not let your tank run fully empty. the gas actually keeps the pump cool. I normally fill up when I'm down to 1/4 tank. don't forget to change the big O ring that seals the pump assembly to the tank, get it from Nissan.
Old Aug 20, 2025 | 06:01 AM
my go to for parts is always Rockauto they have legit parts.
by the time I changed my fuel pump it was noticeably loud. I actually gave the old pump to a coworker who wasn't sure if the pump in his Altima was bad. he said it worked fine for a few days than it quite.
Old Aug 22, 2025 | 09:54 AM
I believe Bosch, Denso, and Hitachi are the top 3 brands when it comes to vehicle electronics.
one time I got a Duralast MAF because I needed a MAF ASAP and it was in stock so i got it. I ran it for a good while than one day I decided to just get a used OEM Hitachi MAF and my engine ran way better and idled a lot smoother. I have had good look with the cheaper brand ignition coils on Rockauto, right now I'm running Ultra Power brand ignition coils.
Old Aug 22, 2025 | 12:29 PM
FanaticMadMax's Avatar
i had to replace mine since the car sat over a year with very little old gas in it, caused the pump to failed and gummed up the turbine. When I replaced it, I got the hitatchi and surprised when I took the old one out and there was a internal fuel filter when I thought these cars don't them, so I went order it since you won't find them at parts store. Got them done, and learned my lesson, never gas set in the tank too long since they do break down and leave varnish and gummy stuff behind if you don't plan on driving the car for a while.
Old Aug 26, 2025 | 07:14 PM
CMax03's Avatar
Please don't surprised that your gas gauge is incorrect and not reading correctly these instrument cluster are problematic with water temp/ gas quantity, tach failures once high mileage is reached. Other words you might actually be lower on fuel than actually indicated.
Old Aug 27, 2025 | 06:46 AM
so far I've been lucky, I'm at 368,XXX miles and my gauges are still ok
Old Sep 10, 2025 | 06:14 PM
CMax03's Avatar
I guess you got lucky my 98 and 2003 Maxima have both had instrument cluster issues either the gas or coolant are problematic
YellowOne
Apr 15, 2007 05:04 PM
99Maxxx
Nitrous
Apr 1, 2006 12:48 PM
waveridr85
Jul 2, 2004 10:06 AM
tampamax
Nitrous
May 4, 2004 03:22 PM
bosco500
Aug 24, 2001 07:10 AM
