2000 Nissan Maxima.. With tons of issues
Old Mar 3, 2016 | 04:09 PM
DLovely16's Avatar
I bought this car 3 months ago! It has been freaking nightmare.. The throttlebody and IAC went out! That was fixed.. I have 2 o2 sensors that are bad and neutral safety switch going out! There's a problem I'm currently having leaving scratching my head.. WTF??? I took off panel where the odometer is to make sure everything is plugged in and that's good! Here's the problem speed odometer stop working! The gas and temp and mileage still works though but if i drive the car for long period of time it will just stop but after letting the car sit for little bit it comes back on.. What in the hell??? Each time it shuts dwn the car runs horrible!! Any suggestions??
Old Mar 3, 2016 | 05:08 PM
cornholio's Avatar
get a odb2 scanner and report back with the codes
when your iacv went out did you inspect the ecm? unfortunately it is common for the ecm to be damaged when the iacv goes on these cars.
maybe new vss will solve speedometer?
Old Mar 3, 2016 | 05:19 PM
DLovely16's Avatar
[QUOT
Only codes it's throwing for 02 sensors.. I kinda had feeling about the ECM but hoping for cheaper and easier fix.. That's not good! I bought this car for 1900 and gonna cost wat more to fix.. It has a lot of mechanical problems! List full
E=cornholio;9098257]get a odb2 scanner and report back with the codes
maybe new vss will solve speedometer?[/QUOTE]
Old Mar 3, 2016 | 05:23 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Sounds like VSS is bad.
Old Mar 3, 2016 | 05:24 PM
cornholio's Avatar
it's not too hard to pull the ecm to check it, might be worthwhile to make sure that's not causing your problems. they can be repaired for about $150 +/- so it's not the end of the world
DLovely16's Avatar
What is VSS?
Old Mar 3, 2016 | 05:28 PM
DLovely16's Avatar
150? Wat if it is? They don't have to reprogram? By time I fix 02 sensors and neutral safety switch and motor mount.. I say I've reached Wat I paid for it.. I LOVE the fact they unhooked battery to erase the check engine light.. I got royally ****ed on this car..
Old Mar 3, 2016 | 05:32 PM
nestorlugo's Avatar
Vss=vehicle speed sensor
Old Mar 3, 2016 | 05:35 PM
DLovely16's Avatar
I just googled.. Thx.. I'm female so I'm in learning process.. First Nissan ever owned and maybe my last.. Didn't think car could have so many problems all at once.. Urrrr
Old Mar 3, 2016 | 05:39 PM
cornholio's Avatar
no, no reprogram needed if you go the repair route
Old Mar 3, 2016 | 05:40 PM
DLovely16's Avatar
Really?? Ok that's good to know! Thx
Old Mar 3, 2016 | 05:51 PM
nestorlugo's Avatar
Well I think any 15yo car has tons of issues with wear items and such, it wouldn't be so expensive if you could hunt down the parts and perform the work on it yourself,
Old Mar 3, 2016 | 05:53 PM
DLovely16's Avatar
I maybe female but I can Google and learn.. If i can change tires, light bulbs.. I can Google and learn.. 😅
Old Mar 3, 2016 | 05:56 PM
Mattx's Avatar
Good luck with finding oem vss sensor. I just had to get a used one. I went to my local nissan dealer and the part for 2002 at least has been discontinued. I didn't think to have him try a different year same trans car though. I'm assuming it's the same. Nissan is really dropping the ball on older parts availability. Good luck.
Old Mar 3, 2016 | 05:59 PM
DLovely16's Avatar
You know why that is right? Their trying get oldwe cars off street.. Their not making money unless their sticking it. To You with finance charges on new car.. And or the ones that are still in the year range to finance..
Old Mar 3, 2016 | 06:19 PM
Bad *** Newb
Junkyard parts, ma lady. Cheap or free
Old Mar 3, 2016 | 06:29 PM
DLovely16's Avatar
Yea. Thought about that too! I'm down for freeeeee! Lol
Old Mar 3, 2016 | 06:32 PM
Bad *** Newb
If the car idles properly, then the ECU is fine. I would still do the TB coolant bypass.
Definitely let us know what the codes are.
Not that you should trust internet people , but maybe a member is in your area that can help.
Old Mar 3, 2016 | 06:39 PM
DLovely16's Avatar
My car not running good at all.. Its fine at first but longer car drives worse problems.. Meaning.. Hesistates when giving gas.. When Its sitting it struggles to keep idol and of give gas and let off it does but starts back up! Same process starts over
Old Mar 3, 2016 | 10:14 PM
maxiiiboy's Avatar
First things first:So, I suggest: Order yourself an ODBC reader. While you wait, clean the MAF (it seems very likely it's either outright bad or at least dirty; instructions here https://maxima.org/forums/5th-genera...10-w-pics.html). Then, depending what codes you get, order all sensors you'll need from Rockauto.com. So, perhaps it's not as bad as it all looks right now. With a bit of luck, you could be in business for perhaps couple hundred dollars.
Adamk8824
Jan 5, 2016 06:04 PM
Pnjboyzz
Jan 5, 2016 09:44 AM
90KYmax
Dec 28, 2015 01:25 PM
Liu Kang
Dec 28, 2015 04:45 AM
tobyhatesmemes
Dec 10, 2015 03:52 PM
