Power Steering Suction Hose?
Old Mar 28, 2016 | 12:57 PM
iTzCloud's Avatar
Ok well my power steering fluid is leaking, my high pressure hose is wet so I figured ok it's that, common problem anyway.
But my Suction hose (the silver webbed thing) coming out of the reservoir is wet too...
You think it's leaking out of both? It doesn't leak very fast but I was wondering if I need a specific hose for that or can I just use any hose? I'd like to replace them both just to make sure.
Thanks!
Old Mar 28, 2016 | 01:03 PM
losifanatic's Avatar
I'm sure any hose would do. I bought mine off eday for cheap. All 3 of my maximas had that hose leak
Old Mar 28, 2016 | 01:05 PM
iTzCloud's Avatar
Ok haha, I just wasn't sure because it looked "special" lol
Old Mar 28, 2016 | 01:26 PM
iTzCloud's Avatar
That's the hose I was talking about, can I just go to like a auto parts store and get a long enough hose to replace it?
Old Mar 28, 2016 | 02:09 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Use a real clamp at the top and it won't leak.
Old Apr 5, 2016 | 05:31 AM
enterconnect's Avatar
Was the return hose easy to replace?
Old Apr 9, 2016 | 07:01 PM
Upperhand's Avatar
What a nasty mess. First clean it all so if you do anything you'll know if it was effective. Before you get crazy with replacing lines check the conection of the supply line (big one) at the reservoir. If the supply line is wet at the reservoir that's probably a lot of the problem. At least put a hose clamp on it, maybe empty the reservoir and clean it up nice for a good seal.
Old Apr 9, 2016 | 07:06 PM
Upperhand's Avatar
^ I meant clean up the connection. The nipple on the reservoir and the end of the hose. Not the reservoir itself.
Old Apr 9, 2016 | 08:06 PM
Bad *** Newb
Yes, that would help.
It's a known problem. Virtually all of them have this problem due to the bull**** clamp. If it's not leaking already, the return hose will start soon.
djloveu
Apr 9, 2018 05:54 AM
tomtek
Apr 22, 2016 10:20 AM
Narreco
Mar 9, 2016 03:20 AM
A36-SR
Mar 4, 2016 05:21 PM
brichi
Mar 3, 2016 01:08 PM
