High idle after car is warmed up
Old Apr 18, 2016 | 06:48 PM
calimaxima2001's Avatar
My 2001 Maxima SE 3.0 A/T acts really weird.
Besides the P0430 (bad precat code), it idles rough a minute into the cold start but drives fine after that. After driving 30m - an hour later, I feel the car fighting against my braking during red lights. When I put it into neutral or park, the idle climbs and holds at a steady 2000 rpm.
I typically restart the car and the issue subsides for like 30m before coming back.
Any thoughts?
Old Apr 18, 2016 | 06:55 PM
MadMax SE's Avatar
Any thoughts?
If it's fighting the braking that means your fully off the throttle. With the throttle closed you should not be idling that high. That means there could be a vacuum leak from the throttle body to the lower intake manifold. Check for dry rotted vacuum hoses or disconnected ones.
Old Apr 18, 2016 | 07:11 PM
mechanic already sprayed brake cleaner throughout the engine bay to check for leaks. None found.
My issues are exactly like this posts:
https://maxima.org/forums/5th-genera...eed-up-2k.html
Has anyone else experienced this?
Old Apr 20, 2016 | 11:17 AM
bump
Maximum Performance
37
Jun 2, 2016 12:28 PM
valerit1
May 19, 2016 04:13 PM
District
Apr 17, 2016 01:16 PM
gtf01
Feb 20, 2016 09:05 PM
Hugolvn12
Feb 15, 2016 09:39 PM
