Rad support
Old Feb 23, 2017 | 05:23 PM
  #41
95naSTA's Avatar
Aftermarket lower rad supports have been ripping apart. OEMs have a much better track record.
Old Feb 23, 2017 | 05:47 PM
  #42
maximatech12's Avatar
This is why I'm using pop rivets in case I have to swap it out. I bought this from a seller that has decent ratings.
It looks solid!
So if aftermarket supports all fail then why so many on the market?
Old Feb 23, 2017 | 06:01 PM
  #43
I got a new hood latch mounting part out of it too! After I lined it up I popped a couple rivets in it
Old Feb 23, 2017 | 06:08 PM
  #44
95naSTA's Avatar
Fair enough on the rivets.
Because a lot of people assume all things equal without doing any research. I just googled "maxima aftermarket radiator support failure" to find those pics.
Old Feb 23, 2017 | 07:08 PM
  #45
I had a clunking noise after the driveshaft I replaced and began worrying thAt it could be been because the support. But I ultimately began to recall that I put a spare on a year prior and it almost fell off. It bent the lugs but could it have cause a popping noise from the bearing?
Also since I released the upper S it could be displaced the gas in the shock or the upper SM bearing. It eventually completely went away after I stopped driving it.
Old Feb 23, 2017 | 08:58 PM
  #46
cornholio's Avatar
He has done his research, even posted in a couple failure threads and continued to go this route despite warnings.
@maximatech, did you weigh both supports before installing? I'm genuinely curious how much lighter/thinner the aftermarket supports are
Old Feb 24, 2017 | 06:25 AM
  #47
I notice a small difference in weight but not much. Gauge steel
The Nissan support is 1.5 mm thick steel and the aftermarket is 1mm thick steel.
I'd look at the aftermarket you'll see two spot welds by the front bracket coming down from the latch. It's another 1mm thick piece of steel that reinforces the area under and front.
If you drill out the welds I recommend drilling a pilot hole first because if you don't get dead center on those you wind up with a steel burr around the back of the hole.
Old Feb 24, 2017 | 08:49 AM
  #48
I would add that I had to drill bigger holes for the bumper mounting unit.
It will fit but a lot of pushing and jacking to get it so that's why I'd recommend ordering from Nissan.
Old Feb 25, 2017 | 06:18 AM
  #49
rebelhell's Avatar
Looks like it's my turn...
Just ordered the parts (OEM). Any advice before I get started?
Old Feb 25, 2017 | 08:05 AM
  #50
Go OEM that's good advise to begin with. Get about 2 dozen drill bits for pilot holes. Then a 1/4" or slightly bigger bit to drill out the welds.
Old Feb 25, 2017 | 04:39 PM
  #51
95naSTA's Avatar
Use a punch to set the drill center and a spot weld drill bit. There's a few inside the unibody rail that are a PITA to get to. I burned through them with a carbide bit that had a long shank.
Old Feb 25, 2017 | 07:11 PM
  #52
Also when taking off the bumper I found these were rusted so bad
Old Feb 27, 2017 | 06:00 PM
  #53
well I got a price on a new OEM so I guess Ill take that route instead.
Old Feb 28, 2017 | 03:02 AM
  #54
rebelhell's Avatar
Still waiting on mine to ship. Just got my order confirmation yesterday. Gotta love parts shops that roll the sidewalks up for the weekend.
Old Feb 28, 2017 | 07:45 AM
  #55
Derrick2k2SE's Avatar
You shouldn't be killing drill bits like that.
Slow the drill down and use a cutting oil or cutting wax.
You shouldn't run a drill anywhere near full speed on metal.
The heat from running fast will destroy the hardness of the bit almost right away. Once that happens the bit is trash.
You'll find that it will cut faster at the proper speed than full speed.
I have bits that I've used over and over to center drill broken bolts. We're talking over an inch of hard steel sometimes. Bits will stay sharp for a long time if you use proper technique.
Old Mar 7, 2017 | 10:08 AM
  #56
I got a Nissan genuine because of the hype here on the org but I believe the aftermarket supports are tough! They are a bit lighter gauge but that shouldnt pull apart. Try a Replacement branded products. Replacement branded is APW's house brand. If you ever have any issues they will hear you out and honor a warranty.
if you undercoat it it shouldn't give you any issues.
Old Mar 7, 2017 | 05:27 PM
  #57
cornholio's Avatar
so you didn't use the aftermarket one after all? why the change of heart?
Old Mar 8, 2017 | 04:13 PM
  #58
I honestly just want the best results here. When I began to reattach the front bumper I said I don't want to remove this ever again. If there was talk about the replacements on EBay failing I just would rather play it safe.
I had a few other repairs New A.C. hose, new Pre cat, new coolant hoses/pipes, ECT. ECT.
I said let's just go with OEM grade here.
it is a better fitment
the subframe was bent a tiny tiny bit out from the issue
Old Mar 15, 2017 | 12:18 PM
  #59
Since I installed a Nissan I i drilled out the welds of the after market.
You see there's a plate inside that is welded to the front. It's L inner bracket. I think if you put this in you'll be fine!
Old Mar 15, 2017 | 12:23 PM
  #60
Those are probably counterfeit supports from China!
Old Mar 17, 2017 | 03:56 PM
  #61
Lines up A LOT better!
$85 support from Ebay.
$300+tax support from Nissan. you see? its a better fit.
Old Mar 21, 2017 | 07:05 PM
  #62
krismax's Avatar
Father of the 00 VI
I find that light grinding a spot weld works better and doesn't put holes everywhere
Old Mar 21, 2017 | 07:30 PM
  #63
I agree! bending back the steel and carefully cutting the welds with a thin grinder would the way to go! This was DIY in my driveway on a car that I wouldn't get but $1200 even if I cleaned real good! If it was a 2012 maxima I would've had it done by a guy that wouldve known that!
Old Mar 21, 2017 | 08:29 PM
  #64
Also when i sifted the boards i saw that someone recommended a spot weld bit.
What the bit does is drills the outer edge of the weld and releases the steel bond without leaving a hole.
I'd If you have a lot of $$$$ invested in your max I'd take that route but my max is stock.
May just turbo charge it eventually because the value has depreciated so much. It gets me where I need to go for right now.
Maxsufr12
Apr 21, 2016 09:48 PM
Roblee
Apr 11, 2016 09:48 PM
iMAK
Apr 11, 2016 05:22 PM
camako
Apr 10, 2016 03:40 PM
gunslinger935
Apr 6, 2016 07:28 AM
