Type of seals used in power steering system?
Old May 5, 2016 | 12:19 AM
Child_uv_KoRn's Avatar
Bad *** Newb
So, I'd like to use some AT-205 in my power steering to stop the rack from leaking (it's really slow, but I am not replacing a rack, ever lol).
I read that some use teflon seals and since AT-205 eats teflon, delrin, and plastic...
Old May 5, 2016 | 11:32 AM
Brudface's Avatar
Pretty sure that the rack seals are either plastic or teflon. I would use the Lucas stuff as it has no solvents, it is just a WAY thicker oil designed to work with the AT fluid already in the power system.
Old May 5, 2016 | 11:41 AM
FanaticMadMax's Avatar
if it's leaking, you should rebuild it, since the leak stopper is only a temp fix, til you get it replaced or rebuilt. Otherwise you're prolonging the inevitable where your rack gonna take a dump if it continue to leak plus a whole big mess spraying all over the engine bay, I have seen that happened in my shop
Old May 5, 2016 | 11:49 AM
Bad *** Newb
It'll just have to leak to till the end of days. That is literally never going to happen. It's not worth the time to do it. If I were doing the engine swap, now, I would think about it, but it's too late for that.
It didn't start leaking until I filled it up fresh after the swap. Aren't previous owners that never change fluids awesome?
Old May 5, 2016 | 06:39 PM
uttadms31's Avatar
My rack's been leaking for years also (247k miles). I started topping it off with Lucas Stop Leak and I only have to top it off a few times a year now. My leak is not near the boots, but where the hoses/lines go to the rack. Not sure if the Stop Leak is more effective here than areas that leak inside the boots.
Old May 6, 2016 | 05:14 PM
SquidBeak's Avatar
Is the leak coming from the yoke adjustment screw (the 24mm screw right next to where the steering column meets the rack)?
I have a very small leak there. I'm currently looking into this stuff.
It sounds like it might do the trick.
Old May 6, 2016 | 11:00 PM
Bad *** Newb
I have a very small leak there. I'm currently looking in this stuff.
I haven't cleaned it off and checked, but that does appear to be the general area.
District
34
May 19, 2016 10:54 AM
SquidBeak
May 1, 2016 03:11 PM
nelgin
May 1, 2016 03:10 AM
maximatech12
Apr 12, 2016 03:55 PM
