After 319,000+ miles......
Old May 19, 2016 | 08:13 PM
quietbone's Avatar
So, after 319000+ miles of driving my 02 Maxima on the East Coast and across US to California, my engine has finally decided to kick the bucket. I took it in to Nissan for replace the Bank 1 Cat converter and I think the mechanics there ****ed up my engine. The body was well maintained and some mods were done to it. 350z wheels, Eiback Springs, Koni yellows, and more. The car looks mean and I dont want to easily get rid of it as it still seems to be in decent condition. So I am in the market for another entire engine assembly installed and my budget is around 3,000. I could buy another Maxima as I recently saw a 6 speed on craigslist for 6k but I somehow dont want to simply get rid of current Max due to mods and stuff. So, does anyone know any reputable and reliable place in Northern California the sells entire engine assembly? I am looking at LKQ at the moment because of their warranty but their engines have high mileage. I am thinking something in the early 100s
Old May 19, 2016 | 08:46 PM
Mattx's Avatar
There's many different options I'm sure but I know there's at least one place in California that sells zero mile reconditioned motors on eBay. I see their posts all the time. They'll even install. Let me find a link for you check back.
https://www.ebay.com/itm/272244882948 try this it may say 350z motor but they do all vq35de motors.
Old May 19, 2016 | 09:10 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Good ol precats still killing it...literally.
I'll keep saying it, 5.7 swap the only thing worth doing.
Your route needs a 6th gen engine with timing chain/guides replaced and gut or throwaway those worthless precats.
Old May 20, 2016 | 04:17 AM
Prophecy99's Avatar
the 5.7 swap is a 6th gen block right?
Old May 20, 2016 | 04:38 AM
Bad *** Newb
Technically, the blocks are all the same :P The heads are different.
5.7 swap would be the 09+ maxima or 07+ altima, etc.
Old May 20, 2016 | 07:24 AM
Prophecy99's Avatar
OK THANKS, YEA i def knew the blocks but. kool so anything past 2009 max or 2007 alt, note taken
Old May 20, 2016 | 07:31 AM
Mattx's Avatar
Technically, the blocks are all the same :P The heads are different. 5.7 swap would be the 09+ maxima or 07+ altima, etc.
I'm not sure if there's a thread that has a step by step guide on what exactly needs to be done for a 5.7 swap. Just an in order step by step without any clutter. From things I've read one thread says one thing then another thread says something else. So I think it's a little confusing to people including me. When it first started I remember reading about needing to grind stuff and cut this. So maybe if there was a clear set of directions all in one spot people would do it more. Maybe like your tensioner/water pump thread. 👍👍
Old May 20, 2016 | 11:50 AM
cdoublejj's Avatar
5.7 Gen? cause that would be a lot of Litters
Old May 20, 2016 | 02:29 PM
Bad *** Newb
Originally Posted by Mattx
I'm not sure if there's a thread that has a step by step guide on what exactly needs to be done for a 5.7 swap. Just an in order step by step without any clutter. From things I've read one thread says one thing then another thread says something else. So I think it's a little confusing to people including me. When it first started I remember reading about needing to grind stuff and cut this. So maybe if there was a clear set of directions all in one spot people would do it more. Maybe like your tensioner/water pump thread. ����
Darren was going post a how-to without all the clutter, but idk what happened. I have most of it in my thread. If you read mine, then you have a very good idea of what you need to do. It's only missing a couple things. I can help anyone that wants to do it, over phone if necessary.
Old May 20, 2016 | 06:17 PM
maxinout93's Avatar
that is amazing mileage for a 5.5 gen
Old May 20, 2016 | 06:23 PM
Bad *** Newb
I've never seen one much over 200 with original precats. Shows how easy hwy mileage is on stuff.
Old May 20, 2016 | 07:20 PM
maxinout93's Avatar
yeah it is ive seen a couple with over 260k. But the engine breathes better doing highway speeds.
Old May 23, 2016 | 01:41 PM
Roblee's Avatar
My 2000 de k has 307k on her, god im getting scared!!
Old May 23, 2016 | 01:57 PM
Bad *** Newb
Why? 3.0 doesn't have grenading precats.
Old May 23, 2016 | 03:56 PM
96SEmaxB's Avatar
206,454 miles on my 5.5, all original cats. But I'll be gutting them this weekend
Old May 23, 2016 | 04:41 PM
Bad *** Newb
Old May 23, 2016 | 05:14 PM
96SEmaxB's Avatar
So u think its too late, 200k miles of engine wrecking precats? Figured I'd at least take care of the front one (easy one)...
Old May 23, 2016 | 05:32 PM
Bad *** Newb
It's never too late until you're burning an asston of oil. You've just been lucky or taking it easy on her.
Old May 24, 2016 | 06:36 AM
Prophecy99's Avatar
yea i got lucky, i got to gut mine at 180k, when i got my originals off the car the elements were in tact. so hopefully no particales or shrapnel.
Old May 24, 2016 | 08:18 AM
96SEmaxB's Avatar
Previous and original owner was an old lady so yes I'm sure she wasn't ******* it out, but like I said hopefully I'll have the time this week to take care of it. Sounds like a ***** but ya, wish me luck
Old May 25, 2016 | 05:10 AM
Prophecy99's Avatar
worst part is removal of 15 year old bolts and exhaust,
gutting is under an hour of work, just get a nice drill (corded) and 18" spade drill bit
Old May 25, 2016 | 08:24 AM
Itz Shak's Avatar
Is it not dangerous to gut one and leave the other?
Old May 25, 2016 | 08:57 AM
Prophecy99's Avatar
both have same problem though, one is just slightly harder to get it.
Old May 25, 2016 | 03:53 PM
NmexMAX's Avatar
dot dot dot ...
Man, if 3k is your limit, then get an 09 and manage it with a Haltech. That be bad a$$.
Old May 25, 2016 | 04:14 PM
Bad *** Newb
Old May 29, 2016 | 08:48 PM
Nyshadow's Avatar
I'm a the same place with my 03. She has 230K starting to burn oil and i have a P300 in the ecu that i can't seem to get rid of. I like the car and am willing to put some money in to her to get her right.
Old May 29, 2016 | 08:49 PM
Nyshadow's Avatar
Link to said thread. Would like to read through it.
Old May 29, 2016 | 09:46 PM
Bad *** Newb
https://maxima.org/forums/all-motor/...to-2002-a.html
Had I known Darren's thread would disappear, I would have done a much more thorough job. If I do another one (sadly, haven't had the opportunity), I will do a proper write up.
blackcyborg009
May 8, 2018 03:21 AM
valerit1
May 19, 2016 04:13 PM
ShunDoe
45
Mar 8, 2016 07:52 PM
Maxima 97 SE
Feb 29, 2016 09:04 PM
