Upgrading my injectors
Old Aug 13, 2016 | 07:52 PM
blowitoutyour's Avatar
I did a little poking around and found that some people are using 350z injectors at 330cc.
Is this the most common injector swap or are others interchangeable?
Old Aug 13, 2016 | 09:49 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Pointless unless you're doing 4" intake (then use 560/570s).
Old Aug 14, 2016 | 06:48 AM
Derrick2k2SE's Avatar
Yup, it's pointless without increasing the intake and MAF tube which will also require a tune before you run the car.
Our stock injectors are more than adequate to handle any bolt on upgrades. If you "uprgrade" the injectors you'll just end up running rich and needing a tune to lean it back out. In fact, tuning after adding bolt on upgrades like headers/intake usually involves leaning out the fuel mix.
Old Aug 14, 2016 | 04:21 PM
Thank you sir.
I'm gonna be doing full intake and exhaust for next spring but if it's gonna get leaned out anyways.....no point.
Old Aug 14, 2016 | 08:12 PM
Itz Shak's Avatar
Originally Posted by blowitoutyour
Thank you sir.
Not leaned out, but rich.
Old Apr 29, 2025 | 12:30 AM
gdbd's Avatar
hello, does anybody have DENSO 297500-0950 dead times ?
Old Apr 29, 2025 | 05:53 PM
uptownsamcv's Avatar
from what I've seen online, the 350Z uses the same injectors as the VQ30DE-K, but the 350Z runs a higher fuel pressure...
6spd_Hayes
Oct 11, 2016 06:51 PM
To the max!
Sep 8, 2016 04:58 PM
To the max!
23
Aug 23, 2016 04:46 PM
Frankie96Maxima
Aug 8, 2016 10:07 PM
ktowbes
Aug 8, 2016 06:41 AM
