Car wont start and feeling defeated
Old Aug 20, 2016 | 10:55 PM
  #41
cornholio's Avatar
Originally Posted by nestorlugo
No one cares what you have to say you fvckin moron!
Amen
Old Aug 21, 2016 | 09:01 AM
  #42
maximatech12's Avatar
Originally Posted by MadMax SE
If you paid 40 for all of the coils, you definitely need to get an ohm meter to check their specs or reinstall the old coils if you have them.
These aren't coil wires and packs they're Japanese transistors they're either good or bad
Old Aug 21, 2016 | 09:22 AM
  #43
MadMax SE's Avatar
What are you talking about?
What are you ever talking about?
Old Aug 21, 2016 | 09:23 AM
  #44
Child_uv_KoRn's Avatar
Bad *** Newb
Old Aug 21, 2016 | 11:52 AM
  #45
ejenzo's Avatar
Originally Posted by child_uv_korn
lmaoo
Old Aug 21, 2016 | 03:29 PM
  #46
Mattx's Avatar
Anyone listening to this tool might as well tow their maxima to the junkyard right now.
Old Aug 21, 2016 | 06:35 PM
  #47
ejenzo's Avatar
Hey all. Been talking on the phone with my best mate and he told me that his car had all the same symptoms and his car died on him(right around the same time as mine) and when he swapped his coils out it fired up. Interestingly enough we bought our coils at the same time. Gonna buy some new coils in the morning and swap them out! Wish me luck!
Old Aug 21, 2016 | 07:00 PM
  #48
maxiiiboy's Avatar
Buy OEM coils only! You can get them for $38/piece, or about $230 for all six. That's a good investment! Here: http://www.rockauto.com/en/moreinfo....431954&jsn=347
Old Aug 21, 2016 | 09:26 PM
  #49
nestorlugo's Avatar
I digress!
Old Aug 22, 2016 | 02:12 PM
  #50
you can't test the continuity on the packs! If you get continuity this means they're no good replace.
Old Aug 22, 2016 | 09:35 PM
  #51
ejenzo's Avatar
I bought them from oreiley's today, swapped them out and still no start. So im gonna turn it over to a pro now. Im tired ha.
Thanks guys for all your help!
Old Aug 23, 2016 | 09:48 AM
  #52
Mattx's Avatar
I bought them from oreiley's today, swapped them out and still no start. So im gonna turn it over to a pro now. Im tired ha. Thanks guys for all your help!
It's the maf. I thought that in the beginning, but when I heard about the cheap coils I thought that could be it. But if not coils then maf.
Old Aug 26, 2016 | 12:04 PM
  #53
Max_nino's Avatar
Where are you in NC ? I was having the same issue and i got a MAF from a junkyard in Goldsboro and it worked perfect. Check Car-part.com for junkyards
Old Aug 30, 2016 | 08:22 PM
  #54
Just test them with a multi-meter you either get continuity or you don't.
If you get continuity replace them. If not they won't cause your issue anyway so what you need is testing devices to perform a complete test.
Because if it's internal engine failure worn valves, ect it doesn't give you a code. I saw on CL that the tensioner could go bad on these cars and if that's the case you won't get a specific code.
Old Sep 21, 2016 | 06:41 AM
  #55
So is there a coil pack testing procedure? What if you hook the injector pigtail up to a battery and jump it? Get a spark plug type fitting and record the data?
I'm concerned it's not already on the market
You could just replace all for a mere $1200.
Old Sep 21, 2016 | 08:01 AM
  #56
cornholio's Avatar
"Just test them with a multi-meter you either get continuity or you don't"
Old Oct 18, 2016 | 07:09 AM
  #57
ejenzo's Avatar
Hey all! Thanks guys for helping me all summer. I found a mechanic to come take a look at my car. So come to find out, that the no start was caused by me not bolting back the Crank sensor. -___-
However since I replaced all those other parts, car runs like a champ!
Old Oct 18, 2016 | 06:59 PM
  #58
I'm surprised he didn't want to replace the ECM
I'd need more ohms more like a 20M slot to test coil
I get nothing testing from the 2M slot.
Would keeping coils together in a drawer damage them? Should these be kept apart? Do they have a sensitive magnetic field?
Old Oct 18, 2016 | 08:24 PM
  #59
mclasser's Avatar
Sam Maxima
24
Sep 10, 2025 06:14 PM
valerit1
May 19, 2016 04:13 PM
ShunDoe
45
Mar 8, 2016 07:52 PM
03Alt3.5Biz
Feb 26, 2016 01:04 PM
RippinUdders
Feb 20, 2016 05:24 AM
