2000 Nissan maxima start only in Neutral
Old Dec 12, 2017 | 02:14 PM
Drbanks1's Avatar
Today I got into a wreck very minor bumper damage, but anyway when i went to start my car it would not start in P(park) and only starts in neutral.. And the green "P" light only comes on the dash when i wiggle the shifter. Sometimes the lights are incorrect on the dash than what gear it's actually in... Please HELP!
Old Dec 12, 2017 | 07:39 PM
FanaticMadMax's Avatar
the problem you're having is your neutral safety switch which is mounted on the tranny where the shifter cable is mounted on to the switch, hope your transmission didn't get hit hard.
Old Dec 12, 2017 | 07:58 PM
Drbanks1's Avatar
OK thank you, hopefully it didn't it only damaged my bumper cover, do you think it could have did severe damage on my tranny??
Old Dec 13, 2017 | 02:27 AM
DennisMik's Avatar
If you had severe damage to the trans, it wouldn't shift correctly (if it shifted at all) and/or be leaking oil.
Then you move the shift lever, a cable moves an arm on the transmission park/neutral switch. Maybe this arm is bent. When you look at the transmission, the neutral safety switch is facing front on the driver's side.
Old Dec 14, 2017 | 10:43 AM
Drbanks1's Avatar
Is this the neutral safety switch?
Attached Thumbnails 2000 Nissan maxima start only in Neutral-img_20171214_055318.jpg   2000 Nissan maxima start only in Neutral-img_20171214_055314.jpg
Old Dec 14, 2017 | 12:10 PM
yep that’s the one looks like you have a lot of road salt corrosion seem like the switch contact might got the same damage from severe corrosion
Old Dec 15, 2017 | 12:07 AM
DennisMik's Avatar
Try putting some lube on the pivot points. They look pretty dry and crusty.
Old Dec 18, 2017 | 02:43 PM
Drbanks1's Avatar
Thanks you guys for all the help I'm just going to replace it.. Also would any of you know what fuse controls the dash lights?? Because my dashboard lights And park lights not working.
Old Oct 7, 2019 | 06:28 PM
pastaben's Avatar
I know this is an old thread, but did you ever resolve it? I have a similar problem with my 2001 GLE Auto. However, it stopped even starting from Neutral. I just wouldn't start because the indicator stays on "D", even though I can move the actual gear selector throughout the positions.
1992maximase30
Sep 24, 2011 06:18 PM
PTNR
Jan 10, 2011 03:47 AM
Pilot8680
Nov 25, 2009 06:42 AM
whitemax28
Mar 1, 2005 08:53 PM
histo12
Sep 26, 2004 07:23 PM
