PO507 after cleaning TB
Old Mar 9, 2018 | 01:10 AM
MaxinO2's Avatar
ok so.. I was replacing my spark plugs and noticed the throttle body was pretty dirty, so I thought cleaning it would benefit. Big mistake!!
High idle (1200 rpm) and horrible gas mileage now.
I inspected for vacuum leaks, bad gaskets, PCV valve, performed idle air relearn, throttle Learning, and all the jazz many times.
I drove it for weeks like this and decided I'd get an OEM salvage throttle body for $40. I basically just wiped this one with a rag and installed it. I performed the pedal dancing moves and cleared the code. I start the car and it sounds better and the idle is about 200 rpms lower than the last TB. However the code comes back shortly after driving and the rpm are still idling at 1000. It's been a week with the new TB and nothing has changed.
So what am I missing here? Maybe the salvage TB is somewhat faulty or the problem is somewhere else?
All idea's welcome, thank you.
Old Mar 9, 2018 | 04:55 AM
MadMax07SL's Avatar
I don't want to sound like I know exactly, but I'd venture to guess the Mass Airflow sensor may be damaged...
Old Mar 9, 2018 | 01:28 PM
MaxinO2's Avatar
Thanks for reply, so I didn't tamper with the MAF and I think the odb code for that problem is PO101 which I've never had. Pretty sure that's not my problem here.
Old Mar 10, 2018 | 06:09 AM
colt149's Avatar
I believed you better off to buy a new throttle body assembly , never buy a used one because you never know if they move the butterfly of the said part. Buy it at courtesyparts.com. P0507 possible causes : intake leak and throttlle control actuator.
Make sure you torque the intake manifold and used a new intake manifold gasket. The rpm for automatic 750 rpm for manual is around 710 rpm
Old Mar 10, 2018 | 06:23 AM
maximatech12's Avatar
Originally Posted by colt149
I The rpm for automatic 750 rpm for manual is around 710 rpm
Where did you get this info?
I was under the impression it was
675RPM for A/T
625RPM for M/T
This is target idle speed figures for the 2002
A couple things I had to check after cleaning the TB
re set accelerator cables untill the hook up is resting on the stopper
And re-set TPS closed position. This is 2001 and the 2002-03 you may not need to perform that
Old Mar 10, 2018 | 12:21 PM
MaxinO2's Avatar
Yeah I know buying a new OEM from wherever would be the way to go, but for $600, that's not gonna happen. At $40 used, I guess I will try as many as I need until this thing works.
I just got another used TB yesterday and am going to try this one out soon. The salvage place I got it from said I can return for full refund or keep exchanging until one works. Not a bad place.
Gonna install the other probably tomorrow. I'll let ya know how it goes.
Thanks for the reply. Cheers!!
Old Mar 10, 2018 | 12:42 PM
mclasser's Avatar
Good luck man. People on here have replaced the ECU to get rid of that code.
Old Mar 10, 2018 | 01:05 PM
What about this TB? Its Hitachi only $172.62 free shipping
2002-2008 Nissan Maxima Throttle Body - Fuel Injection - Hitachi 02-08 Maxima Throttle Body - 6738-01161758 - PartsGeek
https://www.partsgeek.com/gbproducts...ad=47433949932
Old Mar 10, 2018 | 06:18 PM
colt149's Avatar
From Factory Service Manual: Idle speed
M/T: 625 +/- 50 rpm
A/T: 675 +/- 50rpm
Old Mar 10, 2018 | 06:25 PM
colt149's Avatar
You can buy the throttle body in http://www.nwpengineering.com/Phenol...cers.html#BBTB
Old Mar 11, 2018 | 03:17 AM
Child_uv_KoRn's Avatar
Bad *** Newb
I'd exchange it for another at the junkyard. Maybe someone played with it, too. Pushing the butterfuly is known to **** them up in some cases. You did the right thing by swapping and pedal dance. That should fix it. Worst case should be idle air relearn, but reset always works for me.
Or if you know someone locally do a swap to test.
Old Mar 12, 2018 | 03:25 AM
MaxinO2's Avatar
Yes! So I went to pick up the second TB and it looked filthy. Can barely see the metal on the butterfly and it had a small piece of plastic stuck to the end holding it open more. So I was hesitant, but said screw it. What do I have to lose.
Ready for install. I disconnected the battery, removed the plastic piece from TB and do nothing else but install/relearn. So far so good. I noticed a difference almost immediately after starting the car. Idle is down and engine sounds good.
Ohh and most importantly, it's holds a normal idle through every car start and the code seems to be gone. Hope everything continues to work out.
Thanks!
Old Mar 12, 2018 | 03:31 AM
Bad *** Newb
Thanks!
Just spray the **** out of it. If someone cycles the key for you, then you should be able to hit it while it flips.
I guarantee it's black, b/c the precats were killing the engine in the junkyard car...is that what happened to your original engine? Nice mod list, btw.
Old Mar 12, 2018 | 01:31 PM
MaxinO2's Avatar
Actually, I'm not touching this TB and yes it's black. I'm worried that I will mess it up like the first one. If it runs good why clean it? The ECM is made to compensate for however dirty the TB gets.. The computer will re-adjust accordingly I've read. Wish I would of known that before I messed with it..
Although when I cleaned my original I removed it and sprayed that crap out of it. I also used a rag to wipe the entire circumference including the butterfly. I actually moved the butterfly to get a thorough cleaning. That was probably my mistake.. The butterfly has a coating on it, if this coating gets worn off, then the ECM and TB can't communicate within spec and there for causes problems. High idle and horrible gas mileage.
Old Mar 12, 2018 | 06:50 PM
colt149's Avatar
I recommend to use Techron injector cleaner.
Old Mar 12, 2018 | 11:33 PM
Bad *** Newb
As long as you don't touch it...so yeah, that was your downfall
bryanakaslim
Feb 8, 2012 06:46 AM
se_nismo
Jul 11, 2010 02:06 PM
ChrisG
Nov 22, 2006 12:24 PM
madmax97
Aug 6, 2005 08:49 PM
96GreenMax
Detailing
Mar 22, 2004 05:42 PM
