Maxima 01 engine surge while going low speed
Old May 16, 2018 | 06:15 PM
Nearjackie21's Avatar
Good evening everyone i m new here i just recently purchased a maxima 01. The day i got it the car would surge while in park I changed the iac and the ecu. That problem stopped. I got an oil change and a tune up after i did that the gas pedal would get stuck if i m at a red light or too long at a stop sign i would have to tap a little hard on the pedal to go down. Now when i drive at the speed limit 25 miles the engine would surge high passed 2000rpms and i hear a faint hissing sound under the hood. Has anyone had any similar problems with this car? I could really use some suggestions so when i take it to the mechanic he can check for me thank you
Old May 19, 2018 | 02:45 AM
Darren Buckley's Avatar
your symptoms including the hissing is a text book vacuum leak you can check this by getting a bottle of water and slowly pour it around where the hissing is coming from if your engine changes note you know where your vacuum leak is it is probably a loose or broken hose easily replaced. I have had a lot of issues with my maxima I had to replace intake gaskets and all the hoses because of several vacuum leaks.
Old May 19, 2018 | 07:50 AM
Thank you
thank you i will try that
Ilya88
Jan 30, 2020 07:55 AM
3D2kMax
48
Oct 18, 2012 01:00 PM
ds03
Nov 24, 2004 12:07 PM
wojtekj
May 19, 2002 03:26 PM
