Who is the OEM manufacturer of Cam sensors?
Old Jun 19, 2018 | 09:02 AM
rodent_infested_03's Avatar
Hello. My 03 Maxima stalled out on the highway and was difficult to start. Limped home. No codes. After some investigation it would appear that both camshaft position sensor connectors are brittle and broken from years of heat. They do not snap as they should they just pop right off without doing anything which I'm guessing is a bad thing. Could explain why I'm getting no code and it's stalling. Tjen fine. I'm replacing the connector with a new one. I'm also replacing the cam sensors and I'd like to know who is the actual manufacturer of OEM camshaft sensors? Thank you
Old Jun 19, 2018 | 09:27 AM
Prophecy99's Avatar
just get OEM and be done...
after compltely shutting off while driving with no warning or sign of it coming, i wasn't concerned w saving a few dollars.
Old Jun 19, 2018 | 09:40 AM
That's what I'm trying to do. Get real OEM. If I knew who the manufacturer was I could weed out the false claims online
Old Jun 19, 2018 | 11:18 AM
I've been searching and I think OEM is Hitachi and hoping somebody can confirm.
Old Jun 20, 2018 | 05:55 AM
Prophecy99's Avatar
dealership or dealership stores online will give you OEM
i wanted to guess Hitatchi but yea couldnt conifrm 100% so i didn't post that.
but agian if u got to a dealership online or not u should be able to get OEM without knowing manuf
Old Jun 21, 2018 | 12:10 AM
Child_uv_KoRn's Avatar
Bad *** Newb
obviously hitachi and a 2 sec google search reveals...hitachi
The sensors fail, b/c oil leaks inside and shorts out the signal.
Old Jun 21, 2018 | 06:49 AM
Tarzan's Avatar
Oil is used as dielectric. It can't short the sensor. Oil getting in is a downstream of the sensor plastic cracking and tearing coil apart.
Old Jun 21, 2018 | 11:52 AM
Hey thanks. I googled for quite a while before asking. Lots of dead end threads with links to manuals that are deleted. Online sellers claiming OEM, but its not. No clear answer on the updated rear sensor. I tried..
For future reference..
P0345 Bank 1/right/rear: Hitachi P/N CPS0005
P0340 Bank 2/left/front: Hitachi P/N CPS0002 (updated part with metal circular shell)
Old Jun 22, 2018 | 12:53 AM
Bad *** Newb
The one with the angled connector doesn't have an updated design. I'm pretty sure the new ones just have the casing made correctly this time.
Old Jun 22, 2018 | 12:59 AM
Bad *** Newb
Oil's conductivity increases with temperature, there are a lot of additives in engine oil, plus the grade/type of oil makes a huge difference in conductivity (along with oxidation/contaminants as it ages).
There's a reason why if your car shuts off due to cam sensor and won't restart hot, but it will when it cools off. Or when the plugs get bathed in oil due to leaking tube seals, it may only misfire when hot (high voltage helps a lot).
So, I guess for the cam sensor it would be capacitance that ruins the signal and not a short since it's low voltage (although, I don't know if a partial short can be ruled out, b/c idk how high the conductivity goes with aging/temp).
Old Jun 22, 2018 | 06:43 AM
krismax's Avatar
Father of the 00 VI
oil is very conductive.....
Old Jun 22, 2018 | 07:43 AM
Tarzan's Avatar
You can ignore oil conductivity in automotive 12V applications. It is conductive in a scientific sense, that yes, oil condition can be tested by measuring its conductivity. But for the purpose of blaming it for shorting coil in a cracked CPS, no, it's non-conductive. By the time oil gets in, the sensor is already a toast.
An analogy for your: when coil packs crack, we observe misfires due to warpage tearing apart coils, even though there is no oil involved.
Old Jun 22, 2018 | 08:20 AM
Prophecy99's Avatar
nice post ! should help everyone
Old Jun 22, 2018 | 11:05 PM
Bad *** Newb
No idea wtf you're talking about with coil packs. I said nothing remotely related to that.
Old Jun 25, 2018 | 11:28 PM
CMax03's Avatar
How funny... AAD....Lol....Back in the day there was an TSB regarding the Cam and Crank sensors being manufactured with possible defects causing the them to prematurely fail due to corrosion forming on the internal circuit's solder joints...the remedy was found and fixed with an updated version of the OEM sensor... So I would highly recommend your purchase them from a Nissan Dealer online (Tri-Cities, Courtesy, ABC Nissan). These are wholesale prices.....
Old Jun 26, 2018 | 04:06 AM
Prophecy99's Avatar
yes ! and man its scary having a car turn off 100% with no warming whatsoever while driving
Old Jun 26, 2018 | 06:57 AM
Tarzan's Avatar
Coil packs crack just like CPS do, and fail once cracked absent any engine oil. And it's Okay that you did not say anything about them - I had to, as you did not understand the common root cause and its effect on both.
Old Jun 26, 2018 | 08:25 AM
New connector and sensor. Does that look correct?
Old Jun 26, 2018 | 11:10 AM
CMax03's Avatar
Looks really big! Lol...Honestly my sensor's OEM oring looked skinner than that! Matter of fact I was prepared for it to leak and it never did! Just lube it up with motor oil or vaseline so when you slide it in, so it doesn't get damaged!
chopstic
Sep 23, 2018 07:44 PM
Turbobink
Mar 4, 2016 02:06 PM
showstoppa01
Oct 24, 2015 11:01 AM
RR5
Oct 20, 2005 06:47 PM
Terran
Oct 9, 2004 04:37 PM
