Sunroof issue
Old Aug 11, 2018 | 12:16 PM
sjacobs's Avatar
Sunroof issue
Hello all. Im new here as well am I new to my maxima. its a 2001 5 speed SE. Ive had it for a couple of months and did a few things to it and love it. Only problem is the sunroof doesnt work...at all. I replaced the switches and nothing changed. Please helpp
Old Aug 11, 2018 | 03:02 PM
DennisMik's Avatar
Please get in the habit of telling us what year car you have. They are not 100% identical.
Check 2 fuses in the fuse panel to the left of the steering column. Fuse # 10 top row 2nd from right end. Fuse # 13 middle row 2nd from left end. Since these fuses also power other things as well as the sun roof, they may be OK.
Check for 12 volts on the motor itself. It is the white/red stripe wire in pin 1.
If all the fuses are good and you have 12 volts on the motor, then you probably have a bad motor. It could be switches, but you have changed those.
Old Aug 11, 2018 | 03:24 PM
sjacobs's Avatar
Thank you. I will update with results
Old Aug 15, 2018 | 06:52 PM
Derrick2k2SE's Avatar
Have you tried the tilt button?
Old Aug 15, 2018 | 08:16 PM
sjacobs's Avatar
No not yet. Nothing works at all. Ive tried some reset processes
Old Sep 10, 2018 | 01:21 PM
sjacobs's Avatar
Fixed!
I replaced the motor and it now works. But it did the inch sliding thing and now I have to relearn it because its stuck open
smashedpumpkins
Jan 12, 2014 11:02 AM
sgtboehn
May 17, 2010 01:54 PM
Mr Willis
Jun 8, 2007 04:09 PM
ShinkunoNamida
Nov 8, 2004 12:09 PM
Tampa95GLE
Dec 30, 2000 11:03 PM
