Engine covers
Engine covers
so I snapped the head off the bolt that holds the undercover to the car.
this was back in 14' I did this.
I guess I could drill it out and put a plastic push pin in? What are my options?
Drill that sucker out. Start with a small bit and work your way up, but stop short of full size so that the threads won't get damaged. Once you drill it and get through 85% to 90% of the diameter, it will disintegrate and fall out. Or it will be so weak that you could hit it with heat or some WD-40 and it will no longer be stuck and will un-thread itself.
But it never came out as planned. I wound up shearing off the threads flush and now left with just an 8mm hole. 8mm I think is what it is.
I primed the the steel so it wont rust after replacin the W/P.
Could I just get away with a push pin? I think the pins with the phillips head drive located within the wheel wells will snap in.
Thanks what your explaining is exactly what I tried to do around the other side.
lskiat
Jan 10, 2013 07:59 PM
