The speedometer P0500 thing
Hello 5th Gens. 3rd and 4th gen dinosaur stepping from the shadows. Purchased a 2001 cheap and trying to pass inspection.
Codes :
P0500 (VSS circuit A)
P1320 (Primary ignition Signal Fault)
P1612(pending)(key/immobilizer)
P0460(pending)(fuel level sensor A circuit)
Wheel ABS sensors and VSS replaced
No speedo movement at all
Shifts fine (auto)
Starts fine
Idle to be expected, not rough but occasional hiccup. About 140,000 miles. Needs tune up and filters, fresh gas.
Runs fine.
From here I plan on checking all fuses, wires, connections, plugs. I am under the impression that the actual gauge cluster plays a part in connectivity between ECM and transmission speed? Am I going in the right direction?
Codes :
Shifts fine (auto)
Starts fine
Runs fine.
Codes :
Shifts fine (auto)
Starts fine
Runs fine.
Codes :
Shifts fine (auto)
Starts fine
Runs fine.
Test the gauges. Maybe the whole cluster is borked. P1320 is likely a coil pack. See if the dummies replaced one with non OEM. If not, then I guess it could be the thingy wrapped up in the loom. And if not that thingy, then have to swap em out one at a time till code stays off.
Codes disappeared for a few starts and idles to temp. Came back on, o/d light flashing. Is the trans dead or should I keep at the diagnostic clusterphuk?
See what the results are for the flashes. If gears 1-3 drive fine, then maybe just revolution sensor.
And check the codes lol
jfbalkcom
Apr 28, 2011 06:35 PM
