Redline start up on 02 maxima.
Hello, I have an 02 maxima. As i was driving home the other night, it started to rev high and redline. Every time I start it up, it redline's. I've check the gas cable, it returning like it should. I've looked at the butterfly valve. To me it looks to open for idle, about 45° open, but dont know how to adjust. The stop on the gas cable prevents it from closing all the way. Other then that, not sure what the issue could be.
Any help, suggestions, or advice would be appreciated.
Thank you.
Thank you.
First, do you have an check engine light codes? The ECM is pretty good about picking up codes for the throttle control system, unless maybe it's mechanical and not electrical
I can't tell by your description if the TB is stuck open or not. Sounds like an issue with the gas pedal itself or the throttle body. Gas pedal is easy to remove and replace and will only cost around $20 from a junkyard
If you don't wanna throw parts at it you can refer to the EC section of the FSM and with a multimeter start testing voltages
That's not supposed to happen on a 02 since it's drive by wire. You have to have a major failure for your computer to not be limp moding your car. Normally that's by closing the electronic throttle to a minimum position(usually just enough to idle the car but wouldn't go above something like 2k rpm.
Ihave the opposite issue. Consider yourself lucky and check your gas pedal position sensor. Something not right obviously.. then, make sure there's nothing wrong with your Ignition system. Download a technician manual. The abundant. Idk why ppl don't do that more..
Should probably start with the date of manufacture. Are you VQ30 or VQ35?
https://www.nissanpartsdeal.com/part...html?PNC=18150
How do you figure? Throttle body just contains sensors for sending reference for air. It's one piece of 3 needed for combustion and it's not the controller in any sequence of events.
One word. Multimeter...
5v, 12v check , and check continuity. You'll find a how to IF search. But if be starting at the ECU and body control module..
Korn... The throttle body fails CLOSED position. It's a fail safe. Unless someone removed the impossible to move set screw with Hulk like strength or the internals obliterated it's not failing and sucking open. I have two disassembled on my work bench presently. Don't give people false diagnosis, or at least explain how you think that system can fail in such a way to redline. Please explain
Cool. He also said he checked his cable, and my link offers both options depending on engine. So we still need more information to verify what we're dealing with. All speculation until we know if it's fly-by-wire, or cable throttle.
He not coming back. Probably realized it was something silly.
Edit*I see what ur saying he could have essentially an 01 but pre electronic cause of that 6 mo Gap where Nissan started changing everything then changed again 6 months later lol
I agree but the dudes unlikely to know. Cable could just as easily be referred to as wire harness, or conduit, snakes and ladders?... Unlikely op 2 years off on the age. 😁
He not coming back. Probably realized it was something silly like gum stuck on the Accelerator pedal position switch.
d.ceraso
Oct 19, 2021 11:09 AM
murrayrb
May 31, 2003 11:42 PM
