I35 Parking Brake Pedal Adjustment?
My I35 has fairly new brakes all around but when I set the parking brake on an incline the car rolls. I figure it just needs to be adjusted. Is there an adjustment anywhere? The I35 parking brake is a pedal & not a pull handle like the 5th Gen Maxima.
If the actual brake mechanism on the rear is like the 5th Gen, check for rear calipers which may be seized. If it is, your rear brakes are hardly working, and the parking brakes likewise are not really engaging. I changed my calipers out, and parking brake worked much better.
Hmm, I have not tried that although I've set the brake quite a few times which I would think would be the same thing. Is there no manual adjustment for these parking brakes?
maxima uses a hand brake and i'm pretty sure you can tighten the cable if you take the boot off.
look at the cable on the pedal if there's no nut just a barrel then probably not.
ya there is.
ya there is.
MyownNismo
26
04-30-2010 06:02 AM
Minimalmaxima
43
11-12-2005 11:35 AM
