Memory seats
Old Dec 7, 2019 | 03:07 AM
Mjp2231's Avatar
Memory seats
Can anyone tell me how to set and use the memory seat function on an 02 maxima?
Old Dec 7, 2019 | 03:37 AM
J P D's Avatar
Every car I've owned you put everything in the position you want to save, then hold down the memory button you want to save it to.
It'll beep after a few seconds to confirm it was saved.
Another driver can use the next memory function available. When you start up in Park you can switch between the saved settings.
Old Dec 7, 2019 | 08:37 AM
Mjp2231's Avatar
I have a set button, and then 2 more buttons. I was just looking for some clarification because we've tried a few times but nothing has worked yet
Old Dec 7, 2019 | 01:36 PM
J P D's Avatar
My '02 has manual seats, check this video - might help
Old Dec 8, 2019 | 07:27 AM
03_GLE's Avatar
You set your seat to the desired position you want. Then press the "SET" button followed by the particular number (1 or 2) to use for your seat setting. Done
Old Dec 8, 2019 | 10:55 AM
Child_uv_KoRn's Avatar
Bad *** Newb
If only it were that easy LOL. I haven't successfully set them on the MULTIPLE I own with mem seats.
Old Dec 8, 2019 | 04:15 PM
Mjp2231's Avatar
LOL I'm STILL trying to get this to work. I just had to jump on here to say I love your handle. I've been a KoRn fan since the beginning. Been jamming to The Nothing while fiddling with these seats 😂
Old Dec 8, 2019 | 05:59 PM
J P D's Avatar
That's pretty weird.
Setting the Memory Positions
• Push the ignition switch to the ON or ACC position. (The vehicle should be stopped while setting the memory.)
• Adjust the driver’s seat, steering column (if so equipped) and outside mirrors to the desired positions using the adjusting switches for each feature.
• Push the SET switch, and within 5 seconds, push the memory switch (1 or 2).
• The indicator light for the memory switch you select will illuminate for approximately 5 seconds, and a chime will sound when the memory is stored.
• The driver’s seat, steering column (if so equipped) and outside mirror positions are now set to the customer’s preferences.
Came up here years ago too..
https://maxima.org/forums/5th-genera...-function.html
GStrength
Jan 28, 2009 06:39 AM
BMWHIGH1
May 9, 2008 10:21 AM
boatcop1
Jan 31, 2006 07:34 PM
dragon02se
Aug 12, 2002 10:25 PM
