P0505 error code
Old Feb 1, 2021 | 11:56 PM
jcp2's Avatar
P0505 error code
Hi all, My 2001 Maxima SE just threw the P0505 code. I pulled out and checked the ECU / ECM and all the chips look pristine. So can I safely presume that I just need to replace the IACV? I swapped out the 15 amp ENG CONT 1 fuse with a 7.5 amp fuse. I am going to disconnect the electronic engine mounts as well. I just want to make sure that I won't fry the new IACV as long as the ECU is not burnt. I have done hours of searching, my head is going to explode. Thoughts and suggestions are greatly appreciated. Thanks.
John
Old Feb 2, 2021 | 12:40 AM
maxiiiboy's Avatar
You should be fine.
Usually, a bad IACV damages the ECU, not the other way around. P0505 is telling you that your IACV is bad, so don't drive with it - replace it ASAP.
Old Feb 2, 2021 | 10:42 AM
jcp2's Avatar
Thanks for the confirmation. I just ordered the IACV from RockAuto
Old Feb 3, 2021 | 05:50 PM
jcp2's Avatar
Question, Do I need to do any type of re-learn after I change the IACV? There was nothing wrong with the ECU, just swapped out the IACV. My throttle body butterfly valve looked awesome. Just a teeny, tiny bit of carbon
Old Feb 3, 2021 | 06:15 PM
maxiiiboy's Avatar
No, you don't.
Not with the 3.0L engine - no electronic throttle to worry about.
Old Feb 3, 2021 | 06:17 PM
jcp2's Avatar
Thank You for the quick response Maxiiiboy. Much appreciated. Have a happy new year and stay safe
Old Feb 6, 2021 | 12:49 PM
jcp2's Avatar
Help!!!! I changed the OG IACV that with a new one that I bought from Rockauto and cleared the CEL. Drove around yesterday, Idle was great throttle response was great. Started the car just now, and the CEL is back on with the same P0505 code!!! Freaking out, I don't want to fry the ECU. What could be the issue?
Old Feb 6, 2021 | 09:55 PM
maxiiiboy's Avatar
Download the EC section of the FSM (link in my signature, below), and follow the diagnostic procedure starting on page EC-505 and page EC-509 in particular.
Old Feb 7, 2021 | 12:43 PM
jcp2's Avatar
Thanks. I'll give it a go
Old Feb 8, 2021 | 08:34 AM
The_Fixer's Avatar
Dont assume the mosfets are good unless you probed the pins i have repaired hundreds of these ecu's for that issue.
Old Feb 8, 2021 | 11:05 AM
jcp2's Avatar
I tried probing the pins on the connector to the IACV yesterday per the manual. There was a quiet "pop" sound and now the connector is chard and the car won't start at all. Sh*t!!
krismax
39
Mar 17, 2022 09:42 AM
Mike88SE
26
Jul 1, 2019 07:40 PM
iceberg8389
22
Jul 11, 2016 05:46 PM
fuctkeen
Jul 25, 2010 03:30 PM
GoldMax99
Apr 10, 2006 11:20 AM
