PCV Valve hose
Old Nov 29, 2021 | 05:58 PM
maximanut2001's Avatar
PCV Valve hose
2001 Maxima GLE, 141K miles:
So, I did the rear valve cover replacement today. I also did the plugs, upper intake gaskets and nabbed a new PCV valve. The hose coming off the PCV Valve ( hose is part# 11826-2Y006) cracked when remove the old valve. Not surprised as it was likely original and hard as a rock.
What is the diameter of this hose? I can order the official one from nissanpartsdeal (part# 11826-2Y006) or Dorman hose (part# 46013) from Autozone? Otherwise, I am guessing I can just pickup a length of hose and use that? Just not clear on the diameter.
Old Nov 29, 2021 | 10:20 PM
Veewee's Avatar
If I remember correctly, it is 10mm but if want tighten fit can use 9mm hose.
Old Nov 30, 2021 | 05:19 AM
uptownsamcv's Avatar
what I always do is use the open end of a wrench to measure the size of the fitting the hose was on. use an SAE not a metric wrench than go get the size from the parts store.
Old Nov 30, 2021 | 03:27 PM
Legionnaire1856's Avatar
I'm curious what you end up doing...I'm in the same boat. Just replaced the rear valve cover and PCV valve and my hose is hard as a rock with cracks on the ends where it plugs in.
I'm looking at Nissanpartsdeal.com where I usually get a lot of stuff but after tax and shipping I'm coming out at $36. That's a lot of dough for that hose and I don't want to spend it.
Old Nov 30, 2021 | 06:21 PM
I finished putting everything back together today. I ended up just putting a couple wraps of electrical tape on the PCV valve end of the hose that had a small crack. Works well enough for now.
I'll replace the hose later if my rear valve cover replacement job holds out. I have replaced the front valve cover before and it didn't leak after. Hoping for the same on this job. I'll also note that there is a possibility (from my reading of this forum) that it could be an RMS leak. My diagnosis of rear valve cover leaking in the first place is because there was smoke coming from the passenger side area of the intake manifold at the rear valve cover.
Old Dec 1, 2021 | 06:17 AM
That's the same thing that's going on with mine. I could see smoke coming from the front and rear of the engine and visually I could see quite a bit of oil coming from the front valve cover. I replaced the gasket on the front first and it is not leaking, so I went ahead and did the rear one as well. Then I took the car on a 3.5 hour trip and when I got there I popped the hood and there was still a ton of smoke coming from behind the intake manifold...I was hoping it was just old oil that had leaked out from before that I wasn't able to reach back there to clean when I did the job. These oil leaks are killing me...the car is in great shape but the oil leaks will send it to the graveyard before wear and tear does.
I have already replaced the leaking power steering pump with an OEM new unit, new OEM power steering hose, new front main oil seal when I did the belts and pulleys. I had replaced the suspension and steering parts with all new Moog problem solver stuff but the lower control arms were ruined within a month because of the leaking oil. Now my car shakes on the highway when I press the gas, just like it did before.
Old Dec 1, 2021 | 07:52 AM
I haven't taken mine on a long drive yet. Will be making a 30 minute run sometime tomorrow. That should be enough to see. I have also had the power steering hose replaced (used OEM part) and that appears to be doing fine.
If there are more leaks, I'll be getting a new (to me) pickup truck.
d0773d
Oct 4, 2012 08:19 AM
A32Matt
Jan 21, 2008 03:54 PM
redwood_usa
Jan 11, 2007 09:49 AM
NCSUpilot
Dec 22, 2006 06:34 AM
CCx
Feb 22, 2004 04:20 AM
