Clutch issues
Old Jul 8, 2023 | 05:29 PM
John777's Avatar
Clutch issues
I have a 2000 Nissan maxima 5-speed transmission. I have replaced the clutch, slave cylinder and master cylinder but the car won’t go into gear. When I held the clutch Fork with a crow bar it goes into gear no problem. The problem is the pressure in the system isn’t enough to hold the slave cylinder out and hold. All it does when you press the clutch is move out and right back real quickly. I’ve tried bleeding the system various ways but none have really gotten me anywhere. Can someone give me a few ideas on how to bleed this system?
Old Jul 18, 2023 | 03:16 PM
uptownsamcv's Avatar
solve the problem yet?
did you get the message I sent you?
Old Jul 24, 2023 | 11:29 AM
brianmichalski's Avatar
i'm having the same problem with a 2002 6 speed. i replaced the clutch, slave and master, also replaced the clutch line with one recommended on this site and bleed system. clutch fork only seems to be moving about a half inch. when running, car will shift into 1-6 but not reverse, and point of engagement is about a fraction of an inch off the floor. the clutch disk is on correctly. i've already taken transmission off a 2nd time to check.
how far should the clutch fork travel?
could i have done something wrong with the TOB or pressure plate?
Please help. I'm ready to donate the car to a junk yard.
Old Jul 24, 2023 | 12:18 PM
LA02MAX's Avatar
It should definitely travel more than 1/2 inch. Have you looked up the clutch bleeding procedure in the FSM? There are two bleed valves that you need to concern yourself with. One on the slave cylinder, and one on part of the clutch hard line further up toward the firewall.
Old Jul 24, 2023 | 12:42 PM
i appreciate the insight but as i said i've replaced the clutch line completely with a 1 piece that runs directly from master to slave. it was recommended in this forum. the clutch pedal feels ok but engages VERY close to the floor. the fork is traveling only about 1/2 inch. i am desperate for help. i DO NOT want to remove trans a 3rd time.
Old Jul 24, 2023 | 03:18 PM
could i still have air trapped in the slave? i bleed by pump/release AND reverse bleed. no bubbles either way. is there a way to bench bleed the slave cylinder? i did so with the master but not the slave as i didn't know to do it or how if i thought of it. any suggestions? thanks
Old Jul 25, 2023 | 09:06 AM
95maxrider's Avatar
Lightly modded
It sure sounds like you still have air trapped in the system somewhere, but since you've gone to a single piece clutch line, that should greatly simplify things. What brands of master/slave did you go with? It's always possible parts are bad out of the box too. I highly doubt there's anything wrong in the clutch/TOB area, so I wouldn't pull the trans again. You did install the TOB in the correct orientation, right?
Old Jul 25, 2023 | 11:08 AM
yes i think TOB is installed correctly. it went in like the old one - which worked
Old Jul 25, 2023 | 07:31 PM
freezer's Avatar
Checked the clutch pedal bracket? I just had some clutch issues which were caused by failed welds on the pedal bracket. This caused the clutch to be only partially disengaged which made shifting difficult when the engine was running, reverse almost impossible since it doesn't have a synchro
Attached Thumbnails Clutch issues-received_1264858750871086.jpeg   Clutch issues-screenshot_20230723-214946_gallery.jpg
Old Jul 26, 2023 | 05:23 AM
i'll check the clutch pedal but i was under there for the master and things look ok. but a second check couldn't hurt. thanks
Old Jul 26, 2023 | 09:33 AM
I tried the car this morning and everything seemed fine. I took it out and drove it down the street but within a few minutes it reverted to it's old condition - clutch engagement very close to the floor and unable to get into reverse. I figured it was just poorly bled. I've spent 4 hours bleeding (tried pump/bleeder release; vacuum, and reverse bleeding techniques) and I can't get it back to where it was first thing this morning let alone back to normal. I haven't even seen a bubble. What's more, the new suspension parts I put in (bc the old ones were so rusty most had to be cut off) knocked like crazy when I took that short drive. I now officially hate this car. I've ordered speed bleeders that will be here any day. Should I even try them? I can't really get the car to the dealer for them to look at it bc it's not really roadworthy and in any event the car's not worth enough to put any more money in. Any ideas?
Old Jul 26, 2023 | 06:55 PM
Child_uv_KoRn's Avatar
Bad *** Newb
https://maxima.org/forums/all-motor/...ml#post8994708
Old Jul 27, 2023 | 07:08 AM
95maxrider's Avatar
Lightly modded
I still don't really understand how a copper line is any better than a SS line, but I'm glad it worked for you.
OP- I'm not sure where you got your parts from, but if it's local, I would try to exchange for new ones. Things can be bad out of the box.
Old Jul 29, 2023 | 08:00 AM
when I installed a new master cylinder I had to adjust the rod, haven't had any issues since.
eliminating all the factory tubing made the clutch easy to bleed buy myself with a 1/4" check valve and vacuum hose..
Old Aug 2, 2023 | 08:00 AM
Well, here's what happened - I replaced the clutch disk and installed an UNSPRUNG disk. Worked.
Bottom line: DMF did not work with sprung clutch disk.
Not sure if that's a universal or applies just to maximas or just my situation. But after I replaced the sprung disk for an unsprung one everything worked fine. Lesson learned.
Old Aug 2, 2023 | 08:40 AM
95maxrider's Avatar
Lightly modded
That.....doesn't make a whole lot of sense. The stock disc is sprung. Are you using any aftermarket parts in there? Seems like some parts weren't matched correctly or you had the wrong part installed. What made you go with an unsprung disc? That's gonna be brutal on the street.
Old Aug 2, 2023 | 10:45 AM
Bad *** Newb
OP hasn't responded. The other post is a different guy. I didn't even read it LOL.
Unsprung is fine. It's hardly noticeable, IMO. Then again, I rev match every single shift during normal driving.
Old Aug 2, 2023 | 04:19 PM
slvr2KSE5's Avatar
The stock disc is not sprung on the 3.5
Old Aug 3, 2023 | 05:17 AM
95maxrider's Avatar
Lightly modded
Huh, good to know!
Old Aug 9, 2023 | 05:24 PM
John777's Avatar
Clutch won’t engage
My 2000 Nissan maxima won’t go into gear when the car is running but when it’s off it will. The car won’t start in 1st however. I’ve replaced the master and slave cylinder and the clutch line mentioned in this thread. My car still won’t go into gear. What are some possible fixes for this. By the way a while back I pulled the clutch fork with a crow bar and it went into gear fine.
Old Aug 9, 2023 | 05:26 PM
Bad *** Newb
bad newb thread jacking
Need new TOB, so new clutch kit
Old Aug 9, 2023 | 06:13 PM
John777's Avatar
the car also jumps a bit when I try to throw it into gear but it won’t go into gear
mblakney
Sep 17, 2018 05:30 AM
seastone14
Feb 5, 2013 10:55 PM
maxcima
Apr 10, 2011 06:03 AM
max88ima
Feb 15, 2005 08:48 PM
sbrett
Sep 26, 2004 12:52 AM
