Oil leak location
Old Mar 28, 2024 | 07:34 PM
evrgreen's Avatar
Oil leak location
Hello all,
I've been having a problem with oil leaking for a while now and just got around to getting a UV dye kit to find where it is leaking from. I thought it was the oil pan but unfortunately its not. I waited until it was dark and shined a UV light on it. It looks like its coming from the front main seal. Just wanted some conformation before I start taking things off lol.
Pics below, thx
Old Apr 1, 2024 | 06:08 AM
Ksnelgrove's Avatar
Hard to tell from the pics but I think you’re talking about the crankshaft seal. Just had mine replaced. Lasted 20 yrs. If so, important to make sure the pulley is still in good shape. Inexpensive gasket, $200 labor. Might replace your main belt while you’re in there.
Old Apr 1, 2024 | 04:37 PM
uptownsamcv's Avatar
my first guess would be the half moon seals on the end of the oil pan. those seals are notorious for leaking. when I first got my car I thought I had a rear main seal leak and it ended up being the half moon seals. those things can easily mislead you to thinking you have a rear main or front crank seal.
Old Apr 10, 2024 | 03:44 PM
slvr2KSE5's Avatar
absolutely this. in over 20 years of dealing with these ive never seen a front or rear seal leak that wasnt damaged by improper repair. upper oil pan seals? for sure. they shrink, get hard, and crack.
pull the crank pulley and take a close look at the upper seal. takes all of 5 minutes.
burnedplzza
Sep 14, 2023 08:27 PM
ayeimjustmartin
38
Jul 16, 2022 12:01 AM
Yrod6
Dec 29, 2020 06:07 PM
egali045
Jun 2, 2014 06:00 PM
ridinwitha35
52
Dec 15, 2010 06:40 AM
