2001 Maxima P1335 Code
Old Dec 4, 2024 | 07:46 AM
Melvin_Marvelous's Avatar
OBDII scanner threw code for CPK P1335, I replaced the Crankshaft Position Sensor near the oil pan / crankshaft pully. I cleared codes but it is throwing that code again. Could this be a fuse or wiring issue? What should I do next to diagnose fixing the circuit for that sensor? Thank you!
Old Dec 4, 2024 | 12:45 PM
TallTom's Avatar
What brand sensor did you use? If some cheapo chinese brand, swap it out with a Hitachi
Old Dec 5, 2024 | 04:12 AM
I swapped it with a CarQuest sensor but turns out the wire was broken so I had it soldered and heat shrink wrapped. it's fine now. If that one goes out then I'll be on the look out for that Hitachi.
billm
Jun 28, 2013 11:49 AM
browningejm
Aug 8, 2012 06:03 AM
96 SE JET
18
Feb 7, 2011 02:29 PM
