Transmission output sensor craziness (replaced 4 times)
Old Jan 24, 2025 | 11:05 AM
NTU's Avatar
NTU
Hello,
So my transmission keeps slipping and threw a code for the transmission output sensor/speed sensor. I replaced it several times and every time, a few weeks later or a few days later, the problem is back again. What do you guys think the issue is, because it certainly isn't the output sensor anymore, even though it's behaving just like it and keeps throwing codes for it. Bad ECU, bad TCM, flaky wiring? Is it also possible that the sensor itself actually is bad again due to the TCM or ECU keeps taking it out? I've tried different brands of transmission output sensors as well. Looking for any ideas, thanks!
Old Jan 25, 2025 | 12:22 PM
User1's Avatar
There are two sensors.
Old Jan 25, 2025 | 05:58 PM
NTU's Avatar
NTU
Are you saying there's two transmission output sensors? The one I'm talking about is on the front driver-side tucked under the wheel well.
Old Jan 26, 2025 | 05:30 AM
User1's Avatar
Correct.
Old Jan 26, 2025 | 05:31 AM
User1's Avatar
They are both the same. Grab a pair from ebay and call it a day.
Old Jan 26, 2025 | 08:10 AM
RA030726's Avatar
I'm nutty for Nissans
The 3.0 has one
The 3.5 has two
Old Jan 26, 2025 | 08:21 AM
User1's Avatar
RE4F04B = 2 sensors. Specify if you want more specific help.
Old Jan 26, 2025 | 09:29 AM
NTU's Avatar
NTU
I have the 3.0L.
So if the revolution sensor is bad, it will throw the same code for the speed sensor?
Thanks!
Old Feb 17, 2025 | 04:28 PM
User1's Avatar
Well?
Old Mar 30, 2025 | 11:13 PM
NTU's Avatar
NTU
My car has been out of commission since January, finally got around to fixing it. After cleaning up the connections, replacing the sensor and the transmission control unit, still throwing the P0720 code. I replaced all three wires from the VSS to the trans controller and the problem is fixed for good now.
The 2001 Maxima by the way does not have the mechanical speed sensor, only the electric one.
Stagnet04
Jul 12, 2008 12:35 AM
loverholic
20
Aug 18, 2006 08:20 PM
THT
Apr 6, 2005 08:14 PM
liqidvenom
Feb 25, 2004 01:37 PM
99SEmaxima
Mar 9, 2003 08:11 PM
