Dissambley rear brake caliper
Old Sep 9, 2025 | 08:38 AM
Veewee's Avatar
Hello everyone,
I'm in the middle of rebuilding the rear brake caliper, but I have no idea on how to remove the center push rod from the caliper, FSM says remove ring C, then keyplate, and then push rod, but mine is just stuck inside..... Anyone here mind to share some tips?
Thank you very much
Update 1: Did try using pliers to pull it out, no go, and damaged some threads at the push rod.
Old Sep 14, 2025 | 05:30 PM
Complacency Killz's Avatar
Can't even get the caliper off
I wish I could help, (I'm new here) but I'm stuck a couple of steps before where you are. Since you have the caliper off, I'm hoping you could help.
I can't even get the caliper's bottom bracket bolt out. There doesn't seem to be any straight shot at the bottom bolt because of the other rod in the way.
I'm able to get the 19mm socket on the bolt using different swivels or angled attachments. I tried simulating having weight on the suspension by using a second jack, but no go.
I don't have a full (or half full) set of mechanics tools, but I still think I'm missing something, especially since I don't see many posts about getting that bottom bolt out.
Any help you could offer would be greatly appreciated. It is a 2006 Maxima SL with all stock wheels and suspension as far as I know. Although, I just purchased it a few weeks ago.
I'm actually trying to change the wheel bearing.
Thanks, JP
Old Sep 14, 2025 | 05:37 PM
CMax03's Avatar
Thread a nut or 2 on the threads then grab it with pliers!
Old Sep 16, 2025 | 12:56 AM
Veewee's Avatar
Thanks for the tips, but I just gave up and only rebuilt the basic brake section. By the way, the parking brake mechanical section for this caliper seized a long time ago. Maybe this is why it's so hard to pull out the center rod.
Old Sep 16, 2025 | 01:32 AM
Veewee's Avatar
Thanks, JP
Better to start your own thread, as my car is 2001 Cefiro with a 3.0L engine. The rear suspension is completely different from your 2006 Maxima, I think, which has a multilink suspension, but mine has a torsion beam with no rods around the area.
Old Oct 31, 2025 | 12:10 PM
Alright, thanks!
240Z_Master
Aug 22, 2005 11:50 PM
97BLUEMAX
Sep 25, 2003 06:54 PM
nirwhistlr
Aug 25, 2003 10:25 AM
Curt Deiner
Nov 15, 2001 08:45 AM
