squealing on start up
Old Oct 26, 2025 | 06:58 PM
FanaticMadMax's Avatar
when I start up the car, it squeals very loudly, then after it runs for a while it dies down but it does it every start up. I had to pull the alternator since it sounded like it was coming from there, so I replaced the bearing and it wasn't the issue. So could it be the belt pulley tensioner, since I know it's not even that old and I did not over tighten the belt. So I hope anyone out there had that issue and can point me what could it possibly be.
Old Oct 27, 2025 | 05:50 AM
Ksnelgrove's Avatar
Put a big dab of dialectical grease on the UNDERSIDE of the main alternator belt. If it stops squealing you’ve found your prob.
Old Oct 27, 2025 | 08:21 AM
slvr2KSE5's Avatar
baby powder. itll soften the squeal and not grease everything up with silicone.
does sound like belts are loose. also could be a separated damper ring. i had one on my 00 break loose. would scream whenever ac was on. drove it for about 6 months before i decided to look into the problem.
Old Oct 28, 2025 | 10:39 AM
User1's Avatar
Belts and pulleys.
Old Oct 28, 2025 | 02:40 PM
uptownsamcv's Avatar
belt might be loose. check and see how it looks before tightening it, you may need a new one.
shadyonedeath
Jan 31, 2012 02:27 AM
GreenVQ30
Sep 21, 2008 07:40 PM
chillout18
May 8, 2006 03:50 AM
sunysb83
Dec 18, 2004 12:33 AM
orgasmicNYC
Dec 14, 2003 07:46 PM
