sum 1 please help me!!!!!!!!!!!
Old Feb 13, 2002 | 07:44 PM
maxxxed out's Avatar
alrite i was drivin home, when i down shifted into third goin about 60mph, all of the sudden my car loses power and starts stutterin. then the car shuts off!!! goin 50ish. i pull over and try to start but it would start up then shut off. after an hour of tryin to start the car i started the car up but pumped the clutch and it stayed idle. but when i drove off the car wouldnt go past 2000rpm in ne gear. also stutters in 3rd gear and the check engine light is on too. what can be the problem???!!!!!
PLEASE HELP ME!!! i have a 2000 se with 28000miles...is it still under warrentee?? is my car in safe mode??? should i reset ecu???
Old Feb 13, 2002 | 08:04 PM
ajahearn's Avatar
Re: sum 1 please help me!!!!!!!!!!!
Originally posted by maxxxed out
alrite i was drivin home, when down shifted into third goin about 60mph, than all of the sudden my car loses power and starts stutterin. then the car shuts off!!! goin 50ish. i pull over and try to start but it would start up then shut off. after an hour of tryin to start the car i started the car up but pumped the clutch and it stayed idle. but when i drove off the car wouldnt go past 2000rpm in ne gear. also stutters in 3rd gear and the check engine light is on too. what can be the problem???!!!!!
I don't have any specific suggestions, however, it certainly does sound like you have some form of ECU problem. Not being able to go over 2K RPM's indicate may be an indicator of a change-over in the way the fuel system works. I have an 02 SE and I've read in the brochures that a 2nd air plenum opens up under full throttle (and probably only after a certain RPM is reached). Resetting the ECU might solve the problem but probably only temporarily. My suggestion is that you don't try and reset the ECU. Take it to Nissan exactly as it is. The failure codes will still be fresh and accurate and may help them diagnose the problem. Intermittent problems are a ***** to resolve. Hopefully you purchased your car late in 200o and then the 3 year warranty period won't have expired. Good luck, and sorry I don't have a better answer.
Old Feb 13, 2002 | 08:19 PM
a33's Avatar
a33
i think it is a problem with your mas flow air sensor
my friend had a damaged one before and his car died on the highway
then it wouldnt go pass a certain rpm, i think it was 2500
the engine gets to 2500 then just drops down again like a fuel cut, is that what you are getting?
Old Feb 13, 2002 | 08:35 PM
yeah that what is happening. does anyone know how to install the factory intake?? or should i just bring it with the intake on...
Old Feb 13, 2002 | 08:37 PM
Greg's2kGLE's Avatar
Take the aftermarket intake off, put the stock one back on. It isn't that hard if you have a simple rachet set and a screwdriver (assuming you put the intake on yourself).
Old Feb 13, 2002 | 08:46 PM
how much does a mas flow air sensor cost??? that lil thing can do that to a car???
Old Feb 13, 2002 | 09:16 PM
a33's Avatar
a33
listen!!!!!!
you must put the stock intake back, cuz they will not give you warranty with the aftermarket intake
the mass flow sensor costs like 400 us i believe, so i dont think you would want to pay for it
and yes that little thing can do that to a car
when you see that thing you wouldnt believe it, cuz it is so small!!! its just a piece of plastic
that thing is supposed to sense the quality of the air going into the intake to the engine and the thing it damaged now, so it doesnt allow the air into the engine, and the engine doesnt run properly
Old Feb 13, 2002 | 10:13 PM
nvmymax2's Avatar
Have you tried..
Have you tried just resetting the ecu by taking the battery off for a little while. What you discribed sounds alot like the safe mode that my car went in to one night when I raced some one and rode it too hard to the red line in a lower gear. I would try that before I took the intake off and took it to the dealer.
Old Feb 13, 2002 | 10:23 PM
serin's Avatar
1) i say listen to the first post and leave the car as is. DO NOT RESET THE ECU. if you do, and it solves the problem temporarily, good luck convincing your dealer that it was busted.
2) reinstall your stock intake system. no stock intake, no warranty service on maf.
3) talked to daveb today about my own maf. it's $400 originally, then somewhere between 2000 and 2001, nissan replaced it with a new part number that only costs $90. the new one is cheaper, and presumeably better, but there's a tsb to reprogram the ecu with new parameters if you go with the more recent one, which obviously you should.
btw, when you take your intake off to put back the stock one, look at that metal screen on your maf, i bet it's gunked up with crap. maybe it's restricting airflow too much?
Old Feb 13, 2002 | 10:29 PM
a33's Avatar
a33
hey serin
i m not tryin to prove you wrong or something
but i dont think they changed it at all between 2k and 2k1
cuz my friend has a 2k that is supercharged and some other work so he obviously doesnt have warranty
he had a busted one a couple months ago and i put his busted one in my car and got a new one from the dealer from him....
and my car is a 2k1 AE
so i think the only have the $400 ones
Old Feb 13, 2002 | 10:30 PM
Stardust's Avatar
F---ing Kangaroos
MAF
Same thing happened to me, While I was racing a GTP
Old Feb 13, 2002 | 10:42 PM
serin's Avatar
Originally posted by a33
hey serin
yeah, i see what you're saying. but that info is from dave burnette. he looked up the two different part numbers and got the costs for me.
Old Feb 13, 2002 | 10:45 PM
serin's Avatar
from what i understand. the two maf's look the same, behave the same, taste the same. the only difference is something internal that dictates different ecu settings.
Old Feb 13, 2002 | 10:48 PM
a33's Avatar
a33
then im probably wrong on this one
so maxxxed out, you should just take it back to a dealer if it is that cheap
just buy one and replace it yourself
it takes like 40 seconds...
Old Feb 13, 2002 | 10:52 PM
serin's Avatar
40 sec??? i've been trying to find a way to remove my maf from the accordian resonator thing without disfiguring it. what's the secret??
Old Feb 13, 2002 | 10:54 PM
serin's Avatar
cost difference may also be due to different suppliers providing the part which would explain the different part numbers. just an idea.
Old Feb 13, 2002 | 11:00 PM
thanx guy
so it is the maf??? did it break because i have an intake? it seems like alot of ppl have this with there cars due to racin or pushin their car...or are they just poorly built?
Old Feb 13, 2002 | 11:04 PM
a33's Avatar
a33
it might not be the maf, so my advice is that you put your stock intake back on and just take it to the dealer
say that you car just died on you....
Old Feb 14, 2002 | 12:32 AM
think i can make it?
im gonna go to my dealer tomarrow but i gotta drive about 40 miles.. think i can make it with the car studderin and sum times stalin???? wiil i do any harm to my engine???
Old Feb 14, 2002 | 04:31 AM
Max_Gator's Avatar
By the way, if you are driving a 5spd and your car "stalls" while moving, simply push in the clutch, make sure the car is in gear and let out the clutch - the car will start.
You know it as a jump start.
Old Feb 14, 2002 | 05:33 AM
njmaxseltd's Avatar
Why don't you just take a look and make sure the MAF is plugged in still... Unplug it and plug it back in. You just may have a lose connection.
Old Feb 14, 2002 | 06:07 AM
bimmersnomore's Avatar
Re: thanx guy
There does seem to be a lot of MAF problems associated with aftermarket intakes. I noticed that the PCV setup on the stock runs through the air filter before going into the intake manifold. The aftermarkets just run it straight in without filtering it. I am wondering if it is building up gunk in the MAF?
Old Feb 14, 2002 | 06:15 AM
Max_Gator's Avatar
Re: Re: thanx guy
Aftermarket intakes filter before the MAF also.
Old Feb 14, 2002 | 06:31 AM
Re: Re: Re: thanx guy
The ones that I have seen have a straigt pipe that connects to the PCV hose. This runs straight into the air path without a filter. Which ones have you seen that filter the PCV flow? I would like to look at them.
Thanks,
Old Feb 14, 2002 | 06:45 AM
Max_Gator's Avatar
I had a Stillen intake (pop charger) on my car. To install, you pull out the stock airbox, take off the MAF and attach it to the Stillen pop charger then re-attach in same position as stock.
So, the filter is in the same location as stock, it is just a pop charger instead of the stock box.
I believe the same thing is true on the Place Racing Cold air intake .
Old Feb 14, 2002 | 07:17 AM
I have a 2k2, and I think the set up is different than the 2k's. The PCV flow on the 2k2 come in before the MAF on the stock setup and is filtered. On the aftermarket stuff, the PCV isn't getting filtered.
Old Feb 14, 2002 | 10:36 AM
a33's Avatar
a33
you should find someone with a maxima to lend theirs to you then you drive to the dealer with the normal one, and when you get to the dealer just changed it to the damaged one in a plaza near by
Old Feb 14, 2002 | 01:28 PM
hatin the max rite now.....
i just installed my stock intake and bringin it to the dealer tomarrow. think they'll give a hard time??? 0o yea i dont have the stock drop in filter ne more but sum other kind...does this matter?? also does ne one have a close up pick of the stock intake...cause just wanna make sure i installed it correctly...mAY B THEY'LL GIVE ME A NEW ALTIMA TO DRIVE FOR THE DAY TOO
Old Feb 14, 2002 | 02:37 PM
serin's Avatar
Re: hatin the max rite now.....
cool. push for it
Old Feb 18, 2002 | 02:53 PM
got my car back!
i got my car back today from the dealer and it was a blown maf sensor... i also told them to check on the fuel-cut tsb thing...i dont know if they did it or not but my car is runnin again! i have the stock intake back on and the car feels alot weaker or may b its just in my head. should i put my intake back on and risk blowin a maf sensor again????
Old Feb 18, 2002 | 06:23 PM
serin's Avatar
what do mean it's blown? did the sensor thingy get fried or sumtin?
i doubt your intake had anything to do with it, or otherwise there'd be a lot more people experiencing blown mafs. i'd call it a fluke and put your new intake back on.
Old Feb 18, 2002 | 07:14 PM
yea i guess so
i guess i should put it back on since i still do have another year or 8000 miles b4 warentee runs out.
Mar 12, 2020 12:06 AM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
NyC97Max
43
Dec 13, 2002 07:03 PM
NyC97Max
Apr 26, 2002 04:01 PM
NyC97Max
Apr 15, 2002 01:46 PM
