How do you program a 2000 keyless entry remote??n/m
Old Nov 25, 2000 | 03:04 PM
BluethingSE's Avatar
n/m
Old Nov 25, 2000 | 06:45 PM
Max_Gator's Avatar
Read the owners manual?? Are you having a specific problem?
Old Nov 25, 2000 | 07:26 PM
My 4DSC
program the keyless entry remote?
uhhhh...maybe i'm dumb...but i never had to program mine.
Old Nov 25, 2000 | 07:29 PM
max2kgle526's Avatar
If you want to utilize it properly I think it's automatic. I believe its 4 remotes per maxima.
Old Nov 25, 2000 | 07:49 PM
jnm2kse's Avatar
I think
you are asking on how to make the horn not beep when you set the alarm. Flip over the FOB...instructions are on the back of it.
Old Nov 25, 2000 | 08:17 PM
no, I mean how do you program an additional remote.. my bad, should have elaborated a bit more...
Old Nov 25, 2000 | 08:50 PM
MaineI30's Avatar
I don't know if it works the same as the older Max's, but there are instructions around somewhere for programming 4th gen remotes. I think in the FAQ but if not, check usenet. I posted them once, many moons ago.
Ah, it's coming to me... hey try this:
(1) Close and lock all doors.
(2) Insert and remove the key from the ignition more than six times within 10 seconds. (The hazard warning lamp will then flash twice.) At this time, the original ID codes are eliminated.
ID code entry:
(3) Turn ignition key to "ACC" position.
(4) Push lock button on the new remote controller once (for example, if door is locked using the remote controller during this ID code entry enable state, a new ID code can be entered). At this time, the new ID code is entered. (The hazard warning lamp will then flash twice.)
Additional ID code entry
(5) If you need to activate additional remote controllers, unlock the driver's door, then lock again with door lock ****.
(6) Push lock button on the additional new remote controller once.
(7) This ID code entry enable state and setting mode remain until the driver's door is opened.
NOTE
If you need to activate more than two additional new remote controllers, repeat the procedure "Additional ID code entry" for each new remote controller.
If the same ID code that exists in the memory is input, the hazard warning lamps will flash twice but the entry will be ignored.
Entry of maximum four ID codes is allowed and any attempt to enter more will be ignored.
Any ID codes entered after termination of the "setting mode" will not be accepted. Additionally remote control signals will be inhibited when an ID code has not been entered during the "setting" mode.
/aac
mclasser
22
Nov 12, 2020 01:58 PM
TKHanson
Nov 24, 2018 01:39 AM
Need help
23
Oct 2, 2015 08:56 AM
homewrecker
Sep 24, 2015 07:01 PM
flu2000
Sep 14, 2015 12:34 PM
