Street Scenes grill install, HOW THE HELL I DO IT??
I DO NOT want to cut the factory grille. I talked to RUSS who installed it without cutting it, and I know this other guy in the area who also installed it without cutting the Factory Grille. Both of these people used Zip Ties. I do not want to cut it due to the fact I might sell the car at any time.
I got the grille Friday from Greg at Custommaxima on the Group Deal and the main grille looks defective cause when I put it upto it once side is shorter in height.
I mean do I need to re-shape it? What do I need to do? How did you people who DID NOT CUT the grille install this ****?
Dixit
Dixit
Originally posted by SirMaxximus
Let me know if you find out how to install it. I"ll be slapping mines on soon along with the body kit.Maybe It"ll be easy once i remove the front bumper. SirMaxximus
All I can say is, good luck fellas. The grille wasn't initially intended to be installed over the existing grille, so your results may not be all that great, cuz you can easily see the OEM grille behind the Street Scene grille when it's installed over top. Zip ties are really easy to notice regardless of color (yes, even black), especially when you're right next to the car. I strongly recommend having it installed the way it was intended, otherwise you should have probably skipped buying it. Just tryin to help out. Peace.
The biggest problem I have with cutting out the factory grille is that I cannot return it to stock to sell the car. All these mods make the car worth crap.
I mean if there was a "easier" way to remove the front grill without hacking it off, Im all for it.
Dixit
Dixit
I tried putting on my valence this afternoon, but I ran across a few problems. First of all, I noticed that the the street scene's valence itself doesn't reach to the corners of the valence. Is it supposed to? Secondly, the lower "grooves" on the street scene valence don't line-up at all with valence. I don't know if i'm supposed to bend the street scene's valence so that it fits? Third, the street scene's valence doesn't go all the way back to the valences, and I don't understand how the clips attach to the valence.
I thought that this would be an easy install, but it's not. I need to see some pictures if some has any of their install, but overall I need help
I have some pics of the valence installed
link:
http://briefcase.yahoo.com/bc/jayson...t?.dir=/Maxima
link:
Originally posted by TaiwanMaxima
The street scence valence does not reach the corners of the valence. I think it's how the design is. I believe they're were at total of 4 clips. They way i did it was attaching the bottom layer first, by pushing it in. After securing the bottom layer, I did the top. Then you should be all set. Hope this helps.
I have installed the grille on my max and I would recommend doing it like it was intended. I took off my front cap and then used an airsaw to cut out the factory grille. Then I sanded down the areas that I had cut and then painted them black to hide the white appearence that comes from cutting the poly. Then I bent the grille to fit how I wanted it to and then I screwed it in and it looks AWESOME! I am expecting the valence any day now and will post how I installed it and maybe I will be able to help.
Also I know that using Pillagers write up about this in the how-to at the top of the 5th gen section was a big help! Thanks Pillager!
i just had my bodykit installed and I had the guy install my grill and valence too. He did not cut out the factory grill yet somehow still managed to used the clips that the grill and valence came with. The end result was something I wasn't completely happy with cuz the upper part of the border is a bit askew but all in all....it looks pretty damn nice
Oh and my valence didn't exaclty size up within the space it's supposed to go in either.
BigDog, did you install the valence yet? I'm having major problems installing mine.
I dont want to cut it because I want to be able to sell the car like as close to stock as possible when it comes to that.
Dixit
Also, I know that using Pillager's write up about this in the How-To at the top of the 5th Gen section was a big help! Thanks Pillager!
Originally posted by 20 MAXIMA 02
i saw someone on the forum with a custom grille on his 5th gen maxima. It has the chrome mesh grille installed BEHIND the stocke OEM grille. It looks very hot.. anyone have any idea how he did it?
Cheers
AA
Originally posted by BigDogJonx
Im not even working on the valence. My biggest problem is trying to get the damn main grille installed. I cant seem to get it to fit and on top of that it seems shorter in height on one side than the other.
Dixit
Dixit
AA
Pics of custom grill on tip of grill.
For the one it may interest, here is the link to some pics of my custom grill.
http://community.webshots.com/script...bumID=36218860
Cheers
AA
Cheers
AA
Re: Pics of custom grill on tip of grill.
Cheers
AA
Cheers
AA
Re: Re: Pics of custom grill on tip of grill.
Getting an error.
Getting an error.
http://community.webshots.com/user/doublea007
Cheers
AA
I used 7 of the metal clips provided on the entire bottom porton of the valence. Then I decided to zip tie the top portion of the valence for added protection against theft/it falling it out. I haven't had any problems with it yet, and it looks great, and you cannot notice the zip ties at all. Enjoy!
sctludwig
09-01-2022 01:32 PM
