Oil Level Hard to Read
Old May 11, 2002 | 01:56 PM
slo-ryde's Avatar
Anybody else having trouble reading the oil level on the '02 dipstick? The only way I can get any kind of reliable reading is to check it in the morning after it's been sitting overnight, even then it's hard to tell if the oil is half a quart low or half a quart too full.
I mentioned it to the service department and got the classic blank look and shrug of the shoulders.
Old May 11, 2002 | 01:59 PM
jkratzer's Avatar
Re: Oil Level Hard to Read
Yup. This is a classic problem with the 5th gen. I changed my oil at 3K miles and I could not get a good reading on that dipstick until the morning after. I guess Nissan had their experts work on the engine but the dipstick was designed by a newbie. If you do a search you will see this discussed many times.
Old May 11, 2002 | 02:23 PM
2K2_6spd's Avatar
I'ts a common problem with all "OHC" design engines, since the cams are in the head, there must be an ample supply of oil available for them, so after you shut your car off, the oil has to slowly drip back into the oil pan. This is why you cannot get a good reading after you have driven the car, or just changed the oil. The heads themself trap alot of oil, to prevent the cam(s) from starting dry.
Old May 11, 2002 | 02:32 PM
jkratzer's Avatar
I also own a 2000 Honda Oddyssey and it has an OHC engine also BUT the Honda dispstick is not hard to read after an oil chnage. Their dipstick is straight without all of the twists and bends like the Max dispstick has. I think Honda has a better design.
Old May 11, 2002 | 02:37 PM
2K2_6spd's Avatar
Well it all depends on the design of the oil drainback holes, some are larger than others. My 4.6 Mustang is the same way, forget about checking the oil when it's warm.
Old May 11, 2002 | 02:56 PM
TimW's Avatar
The silent but deadly Moderator
its pretty easy...
oil gets in the tube, so pull the dipstick out and wait about 20 secs, the oil will drain back down.. then put the dipstick back in and pull it out quickly.. you should have a good reading. or at least on the second try.
If you dont wait a few secs with the stick out, you can check till you are blue in the face, oil will be ALL over the dipstick. Obviously coming back 5 mins later will work too, but thats not an option most of the time.
Old May 11, 2002 | 03:11 PM
slo-ryde's Avatar
Sorry, but I have to disagree with the comment that all OHC engines have this problem. I've owned too many cars with OHC to list here. None of them were this poorly designed. It looks like the problem is just a bad design. I was hoping someone at maxima.org had heard of a workaround. Oh well...
Old May 11, 2002 | 03:34 PM
2K2_6spd's Avatar
I guess making sure the cams have plenty of oil makes no sense to you. Oh well I don't know what type of magic answer you were looking for. I think Tim lined it out pretty good for you.
Old May 11, 2002 | 03:39 PM
lcf's Avatar
lcf
first time i checked my oil it took about 5 minutes for me to be able to get my damned dipstick to get back in!!
Old May 11, 2002 | 04:02 PM
slo-ryde's Avatar
Whether or not the cams have plenty of oil has nothing to do with the design of the dipstick. This ain't rocket science we're talking about. If you think the dipstick design and the amount of oil the cams have on them are interdependent then you're the one making no sense.
Old May 11, 2002 | 04:08 PM
2K2_6spd's Avatar
Well, maybe I misunderstood your question. I thought you were talking about the oil looking a tad low on the level, but I think you are talking about the oil being splashed all over the dip stick. My bad, 2 different issues.
Old May 11, 2002 | 04:37 PM
john2002max
I have the same problem! the only way to get a good reading is to pull the dipstick out and wait a few minutes. I usually check it 2 or 3 times just to make sure I get a good reading. I have owned many Honda's and have never had this problem. i guess it's just a Maxima thing!
Old May 11, 2002 | 05:39 PM
TimW's Avatar
hmmm
ever feel like your posts are invisible?
Old May 12, 2002 | 03:55 AM
Hobert's Avatar
Re: hmmm
Hehehe I saw it and made a mental note of it. It happened to be the most useful post in this thread.
Old May 12, 2002 | 09:03 PM
slo-ryde's Avatar
Re: hmmm
I tried your suggestion (take the dipstick out and wait a few minutes) but I still can't tell for sure where the true oil level is. As the oil starts to darken I can sort of figure out where the level is.
Old May 12, 2002 | 09:35 PM
[maxi-overdose]'s Avatar
it is hard to read...just follow the instruction in the manual....heat up the car and cool it down for 10min then read it....
Old May 12, 2002 | 10:07 PM
K Pazzo 6's Avatar
yeah i hate reading it...b/c you cant
RinconI30
Nov 10, 2015 10:55 PM
kjlouis
Oct 3, 2015 05:29 AM
Vequity
Sep 10, 2015 05:26 AM
dcardello
Sep 3, 2015 11:44 PM
sdotcarter
Sep 2, 2015 09:53 PM
