235 45 17 Tires
Old May 30, 2002 | 11:37 AM
  #81
roastduck88's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: OOPS!
Originally posted by Hobert
How many times do they have to repeat it. They are not saying you will have problems, but that running an incorrect tire has a higher chance of having problems with sometimes dire consequences. And a couple of people on this site have posted bad things happening when tires that violated spec were used. Yet right after they repeat themselves somebody posts and says the exact same thing.
And the point I'm trying to make is, tires can blow even with stock sizes. It's all about how you take care of your tires and to use your common sense. As long as you do both, running on 235 / 45 is as safe as running your stock tires. So far every situation you guys have proposed where the tires will pop I have already tried and I'm still alive and my tires are fine. (I have Bridestone RE730's by the way). If you guys think it's a risk, then don't do it. Then I wouldn't recommend speeding either nor do I recommend even driving. There are risks in everything. I'm just trying to tell you that there is someone out there that has those tires (me) and had no problems with it whatsoever, even driving agressively on turns and under hot temperatures. I'm sure there are cases of 235 / 45 tires blowing out, but I'm sure there are just as many cases of 225 /50 tires blowing also. You just don't hear about them.
Old May 30, 2002 | 11:45 AM
  #82
TimW's Avatar
The silent but deadly Moderator
roastduck88
just so you know, there appears to be someone who did blow 2 tires by simply cornering with 235's. You probably wont blow one, but you have less margin for error (like proper PSI) than stock size. And really, thats all anyone is suggesting.. You can drive knowing that if something does happen, you can take your tire store to the mat for installing a tire that no manufacturer recommends..
Old May 30, 2002 | 11:46 AM
  #83
Hobert's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: OOPS!
If this was the case then the manufacturers would state this as fact and y2kse wouldn't have to ask for it in writing over and over. But they don't. Because its not.
Old May 30, 2002 | 11:52 AM
  #84
Re: roastduck88
I'm interested to know how they actually blew it? Again, I'm sure there are cases were ppl blow their stock tires just hanging a turn too. If 235's are as dangerous as you said they are wouldn't you have thought I would have blown my tires out already after so many miles and turns? I asked Wheelworks to put 225 / 45 / 17 orginally and they said no because it wasn't up to specs, instead they recommended 235 / 45 / 17 and double checked with Nissan. I didn't ask for it in writing but next time when I change my tires I will.
Old May 30, 2002 | 11:53 AM
  #85
CIRCO's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: OOPS!
OMG roastduck88, I think you "listening but you not hearing me"(training day) I give up!
  #86
y2kse's Avatar
Yup. There's something called "in-spec" and there's something called "out-of-spec". Something is called "out-of-spec" for a reason. It isn't just a word game.
What's surprising to me is that roastduck88's assertion that it's safe to run 235/45R17 tires on 7"-wide rims is clearly addressed in the FAQs. He just won't go look it up. And in keeping with my cherished position as club member #2 of the "I'm not answering the question for the 10th time" club, I'm not answering the question for the 10th time.
Old May 30, 2002 | 11:58 AM
  #87
Tony Fernandes's Avatar
Re: I like...
Originally posted by TimW
Watch Scariest Police Chases IV on Fox, the guy always throws a tire at the end, then rides on the rims in a shower of sparks. I'm sure the tire shop told the owner it was ok to get 235's.. The car jacker had no way of knowing the car he jacked had out of spec tires.. I'm just saying...
My guess on this: Criminals don't care about the cars they've stole, or if it's their car they're either so desperate to get away they don't care what they've run into or over, or they're so drunk they don't know what they've run into or over. AND...
Tire spikes!
Tony
  #88
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: OOPS!
What's surprising to me is that roastduck88's position is clearly addressed in the FAQs. He just won't go look it up. And in keeping with my cherished position as club member #2 of the "I'm not answering the question for the 10th time" club, I'm not answering the question for the 10th time.
When my tire blows I'll let you guys know
That goes back to the speeding is bad thing..
Old May 30, 2002 | 12:00 PM
  #89
y2kse's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: OOPS!
Assuming you're still around to talk about it, that is . . .
Old May 30, 2002 | 12:02 PM
  #90
MAX2000JP's Avatar
I dont understand why this topic comes up 2 times a month. The information is out there. SEARCH AND READ THE FAQ'S!!!!!!!!!!! All you have to do is read it, plain and simple.
I read all the information and chose to run BFGoodridge G-Force KWDS 235/45/17s. I noticed that they bulged a slight bit more than the stock RE92s. These tires are a lot safer than the RE-92s on wet/snow covered roads. Thats why I decided to run this setup. I was tired of literally hibernating when the the snow fell. I took a turn going under 10 mph and almost slid into a mailbox.
  #91
Blackgums100's Avatar
I have 235/45/17's
muahahahahahahhahahahahahahahahahahaa
MUAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA
Old May 30, 2002 | 12:03 PM
  #92
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: OOPS!
Assuming you're still around to tell about it . . .
Again, if it was really as bad as it is made out to be my tires would have been blown the first few (dozen) turns I took.
Old May 30, 2002 | 12:06 PM
  #93
y2kse's Avatar
Precisely. Then do what you want to do, roastduck88. Just don't go preaching that because you decided to run an out-of-spec tire/rim combo, it's all right for everybody else to do the same.
Old May 30, 2002 | 12:10 PM
  #94
I'm not really preaching it, just telling people that I have those tires and it was perfectly safe for me.
Old May 30, 2002 | 12:13 PM
  #95
y2kse's Avatar
The operative words are, "so far". The problem is, if and when you discover that your tires aren't "perfectly safe" any more, you might end up having a really bad hair day.
Good luck.
Old May 30, 2002 | 12:33 PM
  #96
TimW's Avatar
hmmm
[/B]
I don't know, but I would imagine they let their tire get below 28 psi and it rolled off the bead. which, while I know we all check our psi regularly, but if you have a 30-40 degree change in temp = 4 psi.
Like any engineering failure, it usually takes more than one error. When running outside of specs, it just takes less errors to cause an accident. thats speeding, manufacturing defect, wrong psi, bad road, or aggressive turn. But by sometimes no fault of our own, they add up too quickly to react to. margin of safety
Given that, you should be very mindful of your PSI, road and tire condition when running 235. But given that fact that youre already senstive to it, you probably are.
Me? I worry to much, I just want to drive and not second guess my car.
Old May 30, 2002 | 12:37 PM
  #97
y2kse's Avatar
Re: hmmm
Me too, Tim. I have my hands full trying to second guess all the cars around me.
Old May 30, 2002 | 01:21 PM
  #98
ssiperko's Avatar
Good luck.
And face day and whole body day!
Old May 30, 2002 | 01:29 PM
  #99
Re: hmmm
That's very true, but even driving from San Jose to San Francisco everyday (30 degree difference on some days) it still seems fine. I probably check my PSI no more then once a month.
Old May 30, 2002 | 06:21 PM
  #100
I'll just STFFU and f-n Unsubscribe this **** thread.
Old May 30, 2002 | 06:26 PM
  #101
y2kse's Avatar
Ta ta for now!
It's better to give a resentment than to get a resentment!
Old May 30, 2002 | 07:08 PM
  #102
yousapest's Avatar
Hey! Hush-up wit dat engineerin' jive, Norm. We don't wanna confuse no-one around here wit da facts.
I just removed two lug nuts off of each wheel to save weight. I made it to the donut shop without any problems. High School drop- out neighbor kid whose alcholic brother works at an instant oil change place thinks it should be ok.
Old May 30, 2002 | 07:10 PM
  #103
y2kse's Avatar
Old May 30, 2002 | 08:03 PM
  #104
SpicyTuna's Avatar
Re: roastduck88
So people out there guarantee if I run the stock size tire it will never blow? Never go flat?
....that stock size is very magical . No one can promise me anything. The stock tire size is within spec, and is "safer", but not magical there can be failure there as well. Also we dont know ALL the facts to the person with 2 tires blowing. I have *knock on wood* never gotten a flat tire while driving, much less two so this leads me to believe there is something else...granted I/we dont know anything.
As roastduck pointed out there is a risk doing almost everything in life. As he said, you could speed and that would cause crash, so then we shouldnt drive.......everything is a risk, you as the driver/owner choose what risk is acceptable.
Old May 30, 2002 | 10:40 PM
  #105
y2kse's Avatar
Re: Re: roastduck88
I couldn't agree with you more, SpicyTuna. But people can't assess the risks unless they have all the facts. All I'm interested in doing is making sure that they have all the facts before they make up their minds. I assume you don't have a problem with that.
Old May 31, 2002 | 07:52 AM
  #106
Re: Re: Re: roastduck88
I would have to agree with you. I'm just trying to make sure people hear from both point of views.
Old May 31, 2002 | 08:01 AM
  #107
ToYLeT902's Avatar
JET Speed Lab
Old May 31, 2002 | 08:28 AM
  #108
y2kse's Avatar
Re: Re: Re: Re: roastduck88
NP, roastduck88. And you seem to have learned a valuable lesson in the process of presenting your point of view. Rather than argue with the facts, you're now stating your point of view based on your own personal experience. You've stopped generalizing your experience to include what everyone's experience ought to be. And you've stopped making yourself look foolish by attempting to substitute your experience for the combined expertise of an entire industry. That's growth as far as I'm concerned. And several other forum contributors (who shall remain nameless) would do well to follow your example.
Old May 31, 2002 | 10:27 AM
  #109
VTblckmax's Avatar
hmmmm . . .
So for someone in my case who's stock tire blew (could be due to the fact i swerved into a curb ), then merchant tire replaced them with 235/45/17s (which technically aren't the correct size) cuz they couldn't find the stock size tire; are they libel if something happens to the tires as long as i keep them up???
for the record, they're Kumho Ecsta 712's. and haven't had issues with them yet
plp
Old May 31, 2002 | 10:34 AM
  #110
y2kse's Avatar
Re: hmmmm . . .
That becomes a matter of practicality vs legality. You might be able to build a case against Merchant Tire for knowingly mounting out-of-spec tires on your OEM rims. But do you have the time, the resources and the willingness to mount a legal battle against them? Probably not. And they know it.
My advice is simple. Unless you intend to replace your OEM tires with the exact same make/manufacturer, do not purchase tires until you know precisely what you're doing. This particularly holds true if you're changing tire sizes. And NEVER trust a tire dealer. Always consult your Owner Manual and the manufacturer's web site for tire specifications.
Old May 31, 2002 | 12:01 PM
  #111
VTblckmax's Avatar
Re: Re: hmmmm . . .
problem was, i had no time (and of course they didn't have the tire size). i was on a weekend trip 4 hrs away from home. tire busted fri night/sat morning. couldn't get tires till sunday, and they had to fix wheel on monday (the day i was supposed to be back). didn't think - and was told - that the spare wouldn't have made it all the way back home. . . .
oh well, what's done is done i suppose.. i guess the answer to my main concern is that i should look to find a set of wheels that are 17x7.5 instead of looking for a single stock rim.
just more $$ flowing out the wallet . . .
Old May 31, 2002 | 12:19 PM
  #112
y2kse's Avatar
Re: Re: Re: hmmmm . . .
i guess the answer to my main concern is that i should look to find a set of wheels that are 17x7.5 . . .
That's one approach, VTblckmax. Another approach is to purchase a set of tires that do fit your rims properly. Then you can sell your Kumhos on the Parts for Sale/Wanted forum. I don't think you'll have a problem getting rid of them, particularly if there's a lot of tread left on them.
If you want to stay in the same general price range as the Kumhos, take a look at Nitto 450s in 225/50R17. They're available through www.discounttire.com.
Another thing to keep in mind is that most of the guys running 235/45R17 tires on their OEM rims don't seem to be having problems with them. Or if they are having problems, they're keeping real quiet about it. So while there's certainly a greater degree of risk involved in running out-of-spec tires, it may be an acceptable degree of risk for you. You'll have to make that decision on your own, however.
Old May 31, 2002 | 12:38 PM
  #113
VTblckmax's Avatar
Re: Re: Re: Re: hmmmm . . .
quick question for ya...
what's the normal offset for wheels sized 17x7.5 with the 5-114.3 bolt pattern??
(i tried the search function, but that one diagram didn't really give me good answer)
thanks for any help
Old May 31, 2002 | 12:40 PM
  #114
y2kse's Avatar
Re: Re: Re: Re: Re: hmmmm . . .
thanks for any help
That's a rim question, not a rubber question. You'll have to seek out the Master of All Things Alloy for help with that one.
Old May 31, 2002 | 12:58 PM
  #115
VTblckmax's Avatar
Re: Re: Re: Re: Re: Re: hmmmm . . .
oops, my bad. just noticed the name . .
i'll have to search out this 'Master of All Things Alloy' for help then . .
Old May 31, 2002 | 02:55 PM
  #116
Re: Re: Re: Re: Re: roastduck88
A few centuries ago, I'm sure you'd be one of those people that would criticize Columbus about his this theory of the world being round.
That's alot of things the "industry" says, but I wouldn't always believe everything the "industry" says. I still stand by my opinion, those tires are still fine dispite all the miles and turns I take with them, if the "industry" says that the tires are really that unsafe mine tires would have been blown the first week I got them. And there are other people that have those tires and are perfectly fine with it as well. My quote of the day would be "never believe what you are always told". What you choose is up to you.
Old May 31, 2002 | 04:29 PM
  #117
y2kse's Avatar
Re: Re: Re: Re: Re: Re: roastduck88
No, I want the last word, dammit!
Old May 31, 2002 | 04:33 PM
  #118
Re: Re: Re: Re: Re: Re: Re: roastduck88
ROFL!!!!!!!!!!!!!!! I see you finally caught on to what I was trying to do Boy it's hot in San Jose.. ; )
Old May 31, 2002 | 04:36 PM
  #119
SpicyTuna's Avatar
last last last last word
....its normal here in foggy SF
related content:
....get whatever tires you want....I dont care they arent for my car
Old May 31, 2002 | 04:55 PM
  #120
SpicyTuna's Avatar
Funny thing is maxima 17s are 8.0" wide, measured by a caliper
Is this why there is little to no buldge with 235's on the Maxima stock rims? Or are ALL aftermarket 17x7 rims 17x8 when measured by a caliper?
