Reseting the ECU
Old Jun 11, 2002 | 12:39 PM
2001SE's Avatar
Reseting the ECU
If i do it when nothing is wrong...does it hurt anything? will it change something once i reset it?
Old Jun 11, 2002 | 01:30 PM
MaDxKiLLa's Avatar
it just sets everything back to the way it was...like time gets messed up and your radio settings thas all
Old Jun 11, 2002 | 03:21 PM
2001SE's Avatar
is it right that the ECU sees the way you drive and changes itself to the way you drive?
Old Jun 11, 2002 | 03:59 PM
MaDxKiLLa's Avatar
i dont think so
Old Jun 11, 2002 | 04:02 PM
y2kse's Avatar
Originally posted by MaDxKiLLa
i dont think so
Actually, your ECU does learn your driving habits and it adjusts itself accordingly. In a recent writeup in Sport Compact Car on a stock Subaru WRX, the WRX lost 10 hp when the ECU was reset. The reason was because the vehicle had been driven for several days through Wyoming and Montana at speeds consistently exceeding 135 mph! When the ECU was reset, the default driving conditions were restored. There's a dyno plot in the article that proves the point.
The moral of the story is, the harder you thrash your engine, the more power it will generate. The downside, of course, is greater wear and tear on the engine. But hey, it's covered under warranty, right?
Old Jun 11, 2002 | 04:05 PM
MaDxKiLLa's Avatar
icic...well yea the ECU goes back to original though when you reset it....
Old Jun 11, 2002 | 04:08 PM
y2kse's Avatar
Right. Which means that you get to teach it all over again.
Old Jun 11, 2002 | 04:09 PM
2001SE's Avatar
i see that the tranny doesn't act the same as when i first had the car...it changed, the way it moves gears and how it reacts and all. So if i reset it, will it change again and the MPG will go up? because the engine is using less fuel for harsh driving?
MaDxKiLLa's Avatar
smart guy
Old Jun 11, 2002 | 04:11 PM
MaDxKiLLa's Avatar
i dunno why but ever since i reseted my ECU my MPG got horrible....its wierd....y2kse why do you think its doing that?
Old Jun 11, 2002 | 04:14 PM
xChungHsienx's Avatar
opposite for me...before ecu reset 18.2-18.3 now about 21.0 How come max's mpg varies so much. i heard of some people getting 27-28 mpg or even more.
Chung-Hsien
Old Jun 11, 2002 | 04:31 PM
y2kse's Avatar
I could say "it should" and be dead wrong, 2001SE. I'm not an engineer and I really don't know how the ECU goes about the process of learning your driving habits. I just know that it does go through that process.
Old Jun 11, 2002 | 04:48 PM
2001SE's Avatar
how long will it take it to relearn my driving habits?
Old Jun 11, 2002 | 04:53 PM
y2kse's Avatar
I really can't answer that question. Does anybody know? Kevin?
Old Jun 11, 2002 | 05:15 PM
2001SE's Avatar
i started noticeing it a few thousands miles after i drove it.
i am getting now usually around 18mpg like all the time mixed highway and city. should i reset it and see if i get a better gas mileage?
you think i will loose signifcant amount of power?
Old Jun 11, 2002 | 05:19 PM
y2kse's Avatar
Go ahead and reset it, 2001SE. You probably won't notice any significant difference in power.
Old Jun 11, 2002 | 05:40 PM
2001SE's Avatar
alright man...so, its just disconnecting the negitive cable from the battery for a few hours(i'll leave it over night)?
Old Jun 11, 2002 | 05:48 PM
y2kse's Avatar
If you want to make certain that your ECU is completely reset, you'll need to leave the battery disconnected for 24 hours. If you can't do that, at least disconnect it overnight.
Old Jun 11, 2002 | 05:50 PM
2001SE's Avatar
i have to disconnect the negitive cable right?
Old Jun 11, 2002 | 05:53 PM
y2kse's Avatar
I've heard it's best to disconnect the positive terminal. But I've always just disconnected the negative terminal.
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
220k+ A32
Sep 22, 2015 03:08 PM
Colossus
Sep 9, 2015 05:46 AM
